Top Speed Sale Pricing! Greddy timer, HKS boost control, AEM Wideband, DEFI and MORE!
AEM UEGO Digital Single Channel-Gauge Type Wideband
Includes interchangable black and white face plates, silver and black bezels
A wideband UEGO sensor controller accurately monitors Air/Fuel ratios (AFR) during the tuning process to prevent a lean fuel mixture, which could lead to engine damage. AEM has combined its single-channel wideband UEGO controller and gauge display into one unit, uniting unsurpassed AFR accuracy and control with an easy-to-read interface. AEM’s Gauge-Type Wideband UEGO Controller features a digital LED display and sweeping LED “needle” that changes colors as AFR changes from rich to lean. The unit’s 52mm (2-1/16”) gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere.
MSRP: $242.35
NEW SPECIAL PRICING, PM US FOR DETAIL
AEM TRU-BOOST Electronic Boost Controller
Gauge Type Controller
AEM’s TRU-BOOST Gauge-Type Controller is an electronic boost controller that combines the simplicity of a manual boost controller with the added ease of adjusting boost levels through a gauge interface. There is no external interface required for set up, and it is fully functional right out of the box. There are no gimmicks or special software programs included. If you want more boost press the button on the right of the gauge face, and if you want less boost press the button on the left of the gauge face. It’s that simple, and IT WORKS!
AEM’s TRU-BOOST Gauge-Type Controller includes everything you need, including an on-board 29 psig pressure sensor, built-in Overboost protection with two timed shutdown levels, a scramble boost setting and a low-side output for a warning light. AEM offers a 75 psia boost sensor for high boost applications (sold separately).
AEM’s boost control solenoid (included) is the only one specifically manufactured for automotive boost applications, which means it won’t corrode and stick from exposure to rich fuel mixtures, it is pressure tested to 100 psi and includes -4 AN fittings to eliminate any chance of leaks.
MSRP: $335
NEW SPECIAL PRICING AVAILABLE, PM US FOR DETAILS
Greddy Profec B Spec II Electronic Boost Controller
Available in Black or Silver
The PRofec B-Spec2 integrates all the basics of an electronic boost controller, with additional useful options. Use the built-in boost gauge (psi or kPa) to tune in a Lo. & Hi. SET % to raise the boost pressure, then optimize consistency and response with GAIN % and adjust the START GAIN to set initial wastegate response. Also built-in are optional: Warning point, Warning limiter, and peak & last boost record. Compatible with integral and external wastegates and our RSS or SCC’s optional speed trigger.
MSRP: $440
Our Shipped Price: $345
Greddy Profec E-01 Electronic Boost Controller
Includes Boost Controller, Display & Logger
The ultimate in electronic boost control is incorporated in our multi-tasker, the PRofec e-01. Designed as a combination boost-controller, data display/logger and original e-manage programmer. The e-01 can provide superior boost response, increased boost, warning meter functions, 3 channel data-logging and access to programming features provided with the e-manage support tool. Even when used as a boost controller only, the e-01 has features to smooth out the boost curve. With both an auto and manual setting for both external and actuator style wastegates, the PRofec e-01 can alter its compact, high capacity solenoid valve via various RPM ranges. The large LCD screen with green electro-luminescent backlighting is easy to see. Other standard features include two preset boost levels, a timed over-take boost and compatibility with our Remote Switching System. The data display can view 3 different data channels simultaneously such as boost, RPM or any other channel inputted by the e-manage. The data can be logged up for 3 hours on an SD card while also giving warning set points and peak and hold values. There is also a non-PRofec e-01 version that is only used for e-manage programming and datalogging. (Some features require optional harness to be accessed.)
MSRP: $699
Our Shipped Price: $495
HKS EVC Electronic Boost Controller
The new HKS EVC has improved boost stability for maintaining pressure at high RPMs providing increased top-end power, and a new mapping feature allows boost pressure to be precisely tuned for throttle + RPM (or vehicle speed). The new EVC also offers a selectable kPa or PSI unit of measure, and a unique warning feature where if over boosting occurs, boost pressure can be programmed to drop to a user preset level. The new target boost setting and volume **** with three button user interface makes setup and tuning intuitive and simple. The design of the new EVC features a sleek black case with a clear acrylic faceplate and a positive lit LCD display offering a sophisticated look.
MSRP: $650
Our Shipped Price: $545
HKS EVC-S Electronic Boost Controller
The EVC-S features a solenoid valve specifically designed to accurately control boost pressure up to 250kPa or 36 PSI, 2 boost level settings as well as settings for offset and boost response. Also included are: overboost warning with drop boost feature; peak hold boost readings; after-image display; data lock and an internal diagnostic function. Designed to be compatible with both internal and external wastegates, the EVC-S also complements the current HKS Turbo Timers and AF Knock Amp.
MSRP: $375
Our Shipped Price: $329
Topspeed Autosport
2879 S Archer Ave
Chicago, IL 60608
(773)847-1188
2879 S Archer Ave
Chicago, IL 60608
(773)847-1188
price for Defi 60mm ---- Blue- Boost, Water Temp, Oil temp, Fuel Pressure, Oil Pressure, 52mm A/F UEGO wideband shipped to 75069. Does this come with the oil adapter plate to tap in the gauges??
