JDM RHD Battery Cover Kits, Clear Corners, and Skyline Emblems!!!!
Old 10-25-2011, 06:32 PM
Z1Motorsports's Avatar
JDM Brake / Clutch Master Cylinder Cover Kit
JDM V35 Battery Cover (US G35 Brake / Clutch Master Cylinder Cover) kit for all '03+ G35's.
From the factory, the G35 came without a cosmetic cover for the Brake and Clutch Master Cylinders (Unlike its sibling, the 350Z). Lacking this cover, the now exposed reservoirs and fluid lines can be an eye sore.
By using the RHD V35 Skyline's Battery Cover Panels, you can retro fit the piece to cleanly cover the Brake/Clutch Master Cylinders and its hardware. This not only makes the engine bay much cleaner in appearance, but it also protects the various reservoirs and lines from exposure to the elements.
Includes :
1x V35 RHD Battery Cover Panel (Small)
1x V35 RHD Engine Cover Panel (Large)
5x OEM Plastic Panel Clips
1x OEM Panel Support Bracket
1x Z1 Motorsports V35 Battery Cover Support Bracket (Rear)
1x Z1 Motorsports Brake / Clutch Master Cylinder Cover Installation Manual
Please note:
Cutting/ Drilling of the body and supplied RHD Skyline Battery Panels are required. Please read all directions carefully before cutting or beginning installation. Professional installation is highly recommended.
Fits Coupe models ONLY!
BEFORE:
AFTER:
You can order this kit HERE $49
G35 Coupe Clear Corners $40
Nissan Skyline V35/G35 Coupe Emblem Kit $69
JDM Nissan Skyline V35 Grille Emblem $27
*Grille not included*
Emblems can also be Purchased Seperately HERE
Old 10-26-2011, 12:54 PM
BUMP!
Old 10-27-2011, 11:52 AM
BUMP!
Old 10-29-2011, 11:49 AM
Bump!
Old 11-01-2011, 01:14 PM
Bump!
Old 11-08-2011, 02:46 PM
Bump!
Old 11-10-2011, 01:34 PM
Bump!
Old 11-10-2011, 05:20 PM
SuperTrooper699's Avatar
I just ordered a nissan front emblem for my g sedan and it doesn't fit right. is that because i gotta get a different grille or should they fit my stock grille?
Old 11-10-2011, 05:35 PM
Coupe and Sedan Grilles are different, the product listed in here is for a Coupe. We are looking into if Sedan emblems are available. I will PM you as soon as we find out.
-Rob
Old 11-10-2011, 06:31 PM
[IMG][/IMG]
This is it in the grille not cleaned or anything but look at the gap. Is that a coupe emblem then?
Old 11-10-2011, 06:32 PM
you can see where the infiniti emblem was
Old 11-11-2011, 02:46 PM
PM Sent!
Old 11-16-2011, 10:57 AM
Bump!
Old 11-16-2011, 02:16 PM
GTX915's Avatar
coupe clear corners don't come with lights right?
Old 11-16-2011, 04:51 PM
Actually they do, Amber bulbs are included.
-Rob
Quick Reply: JDM RHD Battery Cover Kits, Clear Corners, and Skyline Emblems!!!!
