FS: NEW BRIGHT Reverse/Backup LED Bulbs! SMD and Hi-Power Models, ships same-day
Infiniti G35 Reverse/Backup LED Bulbs! Plug & Play Install! See Install Video!
Infiniti G35 Coupe & Sedan Backup LEDs
Here's a great way to upgrade your Infiniti G35's appearance and safety at night. Diode Dynamics LEDs' are great additions to any G35's tail lights, and can be easily installed, plug-and-play. No resistors or anything needed.
Diode Dynamics offers the brightest, highest-quality bulbs on the market. Your order will ship same day, and we're here if you need us for support and service. These LED bulbs are designed by our engineering team here in St. Louis, and every bulb carries with it a three-year limited warranty.
HP36: (210 lumens) Slightly higher brightness than OEM bulbs.
XP50: (410 lumens) Much brighter than OEM bulbs. These are bright!
Bulb Design
HP36: Full 360 degree illumination with 36 High-Power Samsung LEDs. Aluminum base for optimum heatsinking, and non-polar design for easy installation.
XP50: Each of the four sides of this bulb contains two 5W-rated chips, and the top is fitted with two more under a projector lens. Housed in an aluminum casing with textured finish for maximum heatsinking properties.
The bulbs use an exact terminal and will fit as a replacement for stock incandescent All bulbs use less power and heat than the stock bulbs, and will last longer than your vehicle. Our LEDs use only the best components and are of the highest quality. The bulbs are designed for exceptional heat dispersion, and a diode is implanted to protect the LED from reverse polarity or voltage surge. The LED is wired for 12V operation, the kind found on all vehicles.
Included in your order is TWO BULBS.
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
Diode Dynamics: Backup LEDs for 2003-2008 Infiniti G35 Sedan
Diode Dynamics: Backup LEDs for 2003-2008 Infiniti G35 Coupe
Any questions, feel free to ask via email (contact@diodedynamics.com) Post, or shoot us a PM!
*PM us for the free-shipping code* (U.S. forum members only)
Thanks,
Nick C.
Customer Submitted Pictures:
Customer Reviews:
"These will help you see better behind the car when backing out at night. The cool white light is very bright and sets your car apart from the rest. Highly recommended!" (Posted on July 7, 2013)
"Noticeable increased visibility. Super sharp look at night and install was cake. Slammed the trunk at least 10 times and they didn't budge. Great fitment and highly recommend the highest stage offered. Its worth the coin in function alone." (Posted on May 28, 2013)
"I purchased the Stage 2 LED for my G35. This LED fit perfect in my taillights without any issue. They look awesome at night and they really light up." (Posted on January 5, 2013)
I have the led kit with the license plate bulbs and they are really cool. Stage 2 lights up the plate and the road below in a nice and noticeable white light. Map, door, trunk and plate is a cheap package, easy install and big bang for the buck.
Don't have the reverse lights but I'd bet they are as good. A little pricy IMO for the amount of time I'm in reverse but still thinking about it.
