FS: Osiris/Cipher by Uprev - reflash your own ECU w/ custom maps, adj idle RPM & ign
Old 10-26-2007, 01:11 PM
dTor's Avatar
Exclamation FS: Osiris/Cipher by Uprev - reflash your own ECU w/ custom maps, adj idle RPM & ign
SOLD!!!
I'll have pics up this evening.
I'm returning my car back to stock. I am about to reflash my ECU back to stock with the ROM Jared at Uprev emailed me. Once I do this, I'll email Jared confirmation that my ecu is stock and he will be able to unlock the Osiris cable from my car. It can then be used on any compatible car (03-06 G35 Coupe or Sedan, 03-06 350Z, & Titan).
If you're not familiar with Osiris, go to www.uprev.com. It is a user flashable ECU reprogramming software package. Jared at Uprev will make a custom map based on your mods and email the ROM file to you. You will be able to then upload (reflash) your ECU with the new tune. You then do datalogging with the Cipher program, recording the values required by Uprev, send that info back to Jared, and he will adjust your map accordingly.
You also have the option of having FIVE different maps that are instantly switchable, on-the-fly, using your steering wheel cruise control buttons. I currently have three maps - stock, valet, and max-tuned.
Basically, there is no need to bother spending over $500 PER FLASH and having your car down for several days while you send your ECU to Technosquare or the other reflash companies.
There is no extra charge to have new maps created for you, and there is no limit to the number of maps Uprev will make for you.
Also, my setup includes an adapter box for '03s that only have 4 pins in their ALDL. I'll explain this to whoever purchases this software if they have an '03.
The most recent firmware update has already been performed (v1.40) and everything is great. I could write a novel on all of the things you could do with this software, but I'll let you do your research. Also check out the tuning section here and also on my350z.com.
Also, Osiris (the reflash portion of the software) is the only thing that is "locked" to one car. You can use Cipher (the car diagnosis/datalogging software) on as many compatible vehicles as you want. You can permanently adjust idle rpm (+/- 250 rpm) and base ignition timing (+/- 2*). Basically, you can do everything that Nissan's ConsultII can do.
Thanks!
Old 10-26-2007, 09:19 PM
dTor's Avatar
bump
Old 10-26-2007, 11:06 PM
dTor's Avatar
Sold!!!
06g35
02-14-2022 05:59 AM
esotericrider
V36 General Tech Questions
03-04-2019 07:53 PM
Mad A
Not G35 Related
12-08-2015 01:45 PM
SilverG123
Engine - Electrical
09-04-2015 01:12 PM
pdexta
Tuner & Dyno
09-02-2015 01:03 PM
Quick Reply: FS: Osiris/Cipher by Uprev - reflash your own ECU w/ custom maps, adj idle RPM & ign
