DIY: How to make your own double din w/ your oem Faceplate
#66
I wonder how much you could inset a touchscreen netbook or something in that spot... I've got a extra stock faceplate from the DD conversion in my wife's. If you were to go without the stock navi or storage compartment there, that's a good chunk of real estate to fill. With screen.
#67
Upgrade Help
I am considering replacing my factory head unit with an aftermarket DD touch screen navi. Are the AC/Climate controls dependent on the factory head unit or the board behind it? To simplify; I may attempt to keep factory dash (NO kit) Cut to fit aftermarket DD Unit use original climate controls and install new DD H. Unit.
Thanks
Thanks
#74
oldmanriver, you do not have permission to access this page. This could be due to one of several reasons:
1.Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
2.If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation.
It says registered user under my UN.
