DIY: racing seats with no airbag light.
Old 12-07-2006, 05:29 PM
accordfreak's Avatar
Those who want to add racing seats with no airbag light read below. Also, with this mod, all the other airbags will be active.
i bought a $0.95 2.2 ohm 1/2 watt resistor. (the resistor tricks the system into thinking an airbag unit is there.) I then stuck the resistor in the plug, wrapped it tightly with electrical tape and did the reset procedure below.
Nismo sells the same thing for 50 dollars. Get it at radio shack for .95 cents.
from my350z.com
For the Airbag Reseting procedure…You must first change the SRS system to self-diagnosis mode, and then back to user mode to clear the airbag fault you might be getting after unplugging the side-impact seat airbag and driving with the car..
How to Change to Self-Diagnosis Mode:
1. Turn Ignition switch from OFF to ON.
2. Within 1 second after air bag warning lamp is on for 7 seconds and turns off, turn OFF ignition switch
3. After ignition switch is turned off, wait for more than 3 seconds.
4. Repeat steps 1 to 3 twice. (perform 3 times in total)
5. Turn ignition switch ON again (turn to Diagnosis Mode.)
Turn to USER mode
1. Turn Ignition switch to OFF to ON.
2. Within 1 second after airbag warning lamp is on for 7 seconds and turns off, turn off the ignition switch.
3. After ignition switch is turned OFF, wait for more than 3 seconds.
4. Repeat steps 1 to 3 twice (perform 3 times in total)
5. Turn ignition switch ON again (Turn to User Mode)
no more flash
yosip1115 (08-08-2016)
Old 02-18-2007, 03:19 PM
GWord256's Avatar
Could you specify which wires are for the airbag? Color of wires would probably be best, or a picture.
Old 02-18-2007, 05:25 PM
all yellow plugs/wires are for the AIRBAG.
Old 03-28-2007, 08:06 PM
GWord256's Avatar
Can (or has) any one sucessfully done this with the curtain airbags?
Old 03-29-2007, 07:46 PM
GWord256's Avatar
FYI: This can be done with the Curtain Airbags. I couldn't find a 2.2ohm at RadioShack so I wired some 10ohms to get ~2ohm. No more airbag code from the curtains.
But I want to let it be know that this doesn't work for the passenger seat on my car. I have a '07 coupe. There is another sensor in the passenger seat that senses when someone is sitting in the seat. I wouldn't know how to work around this sensor. Just letting you know!
Old 03-29-2007, 08:09 PM
G35 Mass's Avatar
Im not sure how "smart" the seat-occupant sensor is, I would think it is some sort of switch that closes when a heavy enough load is applied to it. Some car manufacturers have "smart" seats that detect the weight of the occupant to determine how fast the airbag should deploy and with what force. That would probably be a little more difficult to trick.
Old 04-26-2007, 12:34 AM
bbboltz's Avatar
so where is the Curtain Airbags??? I took off the b pillars and I dont see any airbag nor the yellow wires.... Where was it?
and can someone confirm the location of the front seat airbag plug fromt he picture and if the resistor is in CORRECT place???
Old 04-26-2007, 05:43 PM
GWord256's Avatar
Responded to your PM. Hope this pic helps.
Old 06-10-2007, 11:17 PM
Julian's Avatar
nice !!
Old 01-04-2008, 06:51 PM
thatg's Avatar
yeah who carries these 2.2 ohm red red gold gold resistors. i went to radioshack they dont carry them at all, just 220, 2.2k, 22 everything but 2.2 really
Old 01-04-2008, 07:47 PM
cungkpham's Avatar
yeah i purchased the 2.2K ohms, but have NOT tried it. DID he really mean 2.2k ohms OR 2.2 ohms?
someone please verify.
Old 01-04-2008, 08:25 PM
thatg's Avatar
the person in this post specified not the 2.2k he says red red gold gold which the 2.2k are not https://g35driver.com/forums/audio-video-electronics-diy/158005-diy-cancel-airbag-light-proper-way-07-weight-sensor-bypass.html
Old 01-04-2008, 11:02 PM
cungkpham's Avatar
ok thanks for clearing that up. Radioshack did not have the 2.2 ohm resistor, so i assumed (yeah yeah yeah) that he mightve meant 2.2K...
Old 01-05-2008, 12:00 AM
Quick Reply: DIY: racing seats with no airbag light.
