MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area - V35 > Audio, Video & Electronics
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Welcome to G35Driver.com!
Welcome to G35Driver.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today!
Thread Tools Rating: Thread Rating: 2 votes, 4.50 average. Display Modes
  #181
Old 04-04-2008, 07:29 AM
i'm thinking i may need a new amp. one that accepts balanced input.. would this make any sense?
  #182
Old 04-07-2008, 11:56 PM
Just want to thank dR6 for the great instructions. The install only took me about two hours start to finish and everything works great!
  #183
Old 04-08-2008, 01:43 AM
OK, question 1 of 2..with this wiring, i don't understand how the low outputs from the bose system headunit are balanced? there's only two wires + and - for each channel where balanced signals consists of three wires. Is it safe to tap and connect rca plugs on these wires and connect it to an amp without balanced inputs?
Quote:
BOSE WIRING COLORS AND SPEAKER SIZES
Head unit output colors
The (+) are all on the same side of the connector.
Head Output Front Right + Orange/Blue
Head Output Front Right - White/Blue
Head Output Front Left + White
Head Output Front Left - Orange
Head Output Rear Right + Blue
Head Output Rear Right - Pink
Head Output Rear Left + Teal
Head Output Rear Left - Purple
Remote Wire Light Blue/ Silver
__________________
Stock 03 Diamond Graphite, 6MT coupe, stock 18" wheels, everything else...you guessed(guest) it, plain bone stock...maybe
  #184
Old 04-08-2008, 01:57 AM
Quote:
Originally Posted by Gilley
Read the first page of this thread. It tells you what wires to tap into and what to do.
The OEM HU does not have a sub out. The Bose amp takes 4 channels in from the HU and sends 4 channels out left, right, front and rear, and also sends signals to the 6x9 fake subs. I don't know if the 6x9's are stereo, but all that signal splitting happens in the Bose amp.
Question 2 of 2...with 4 channel input...and 8 speakers going out but with the signal splitting happening in the bose amp...is it safe to assume that all the speakers act individually @ 2ohms each? or a pair of speakers together at 2ohms(eg. the front left door + left tweeter = 2ohms since there's only one pair of wires running to these speakers)?
__________________
  #185
Old 04-08-2008, 08:56 AM
Tweeter impedance doesn't have much effect on the overall load to the amp. The front component system is 2 ohms for each side.
__________________
Sean
Florida G Club '03.5 Caribbean Blue 5at Sedan w/ a few mods, '04 Laser Red 6mt Coupe w/ more mods, 06 FX35 bone stock
  #186
Old 04-08-2008, 11:20 PM
Quote:
bump....anyone? from searching around, seems like plenty of people have already spliced in some RCA plugs and works fine...but it's still a question if their amp accepts balanced or unbalanced inputs.
Does bose indeed have balanced signals?... or is this just a rumor/hype that people just accepted and have spread unknowingly? Any info would be great...thanks guys
__________________
  #187
Old 04-09-2008, 10:09 PM
I can't shed too much light on the subject but for now, I know that my amp that doesn't accept balanced inputs is only putting out a very small amount of bass to the sub. I have ordered a JL 250/1 which does accept balanced inputs and plan on trying that ASAP when it arrived. I'll give you an update when I get a chance
  #188
Old 04-10-2008, 01:46 AM
I have a pioneer headunit running to the bose amp recently, and today i just recently took the bose amp out and replaced it with a Rockford Fosgate 4 channel amp(2ohm stable), no balanced inputs.
I tapped into the existing wires coming from the headunit(low level outputs) and also used the existing speaker wires to connect to the speakers from the speaker output of the RF amp. I figure this would be great, i don't have to run RCA's and speaker wires. Plus my pioneer headunit shouldn't be putting out balanced outputs.
Problem is, i'm getting a lot of noise. even with the engine off and even with the volume all the way down. I pulled off the rca plugs and it seems like the noise is coming from them.
Are those existing wires i tapped into with rca connectors still have a balanced signal? Is there a module or device of some sort in between the run from the headunit to the trunk? Man, i'd hate to have to run some new RCA's from the front to the back but i guess i have no choice.
__________________
  #189
Old 04-12-2008, 08:47 PM
ok, i ran seperate RCAs today instead of splicing and using the orginal wires of the low level outputs. Much much much....did i say much? much better.
...must be a junction box, module, converter, etc. somewhere in the middle of the stock low level outputs . I was probably still getting a balanced signal even with an aftermarket HU and aftermarket amp. Stock bose speakers sounds pretty d@mn good, IMO.
__________________
  #190
Old 04-20-2008, 03:09 AM
Well after a few eBay foul-ups as far as amps I finally received the JL 250/1 mono amp this weekend and installed it. You can actually hear the sub now! I'm not sure if I can attribute that to the amp supporting balanced inputs or the extra +/- 100 watts that this amp has but it finally sounds good.
I did have one more question though.. What did you mean about running the amp (sub amp) after the stock amp? I basically wired it how the directions earlier in this thread advised.. running off the blue plug going into the stock amp.. Would this be considered correct or is there a way to get even more power out of it?
Sorry for sounding like such a newb.. I've just never wired into a stock head unit, let alone stock amp. Thanks for the help thus far, though!
Tony
  #191
Old 04-27-2008, 09:43 PM
Just wondering if anyone get engine interference on their radio's after installing an amp and sub? Since my install I am getting this, does anyone have any suggestions?
  #192
Old 04-27-2008, 10:25 PM
Mine doesn't have noise.
check your ground points.
How is everything wired?
__________________
Sean
  #193
Old 05-09-2008, 02:46 AM
hey guys would this amp work Alpine MRP-F250 amp if i wanted to hook it up to my stock bose head unit and run a 10inch type r off it
  #194
Old 05-11-2008, 09:33 PM
Send a message via AIM to boinkee
i just installed my sub following dr6's DIY (Thanks dr6!) and using the exact same components but the bass is really weak, and when i try to increase the boost i just hear soft distortion. any ideas on what's going on? maybe a bad amp?
  #195
Old 05-14-2008, 12:05 AM
infinus's Avatar
2008 Lexus IS-F
My Garage
Just as an FYI to anyone planning to do this, if your running a infinity REF1600A amp, the infinity tech I spoke to says it does indeed accept the balanced input signal, waiting on the box to finish getting built then hopefully by tomorrow night I'll be done =)
is anyone else running the infinity perfect 12 DVQ? would two be overkill?
__________________
My work: infinusphoto.com My car: 2008 Starfire Pearl Lexus IS-F
Tags
06, 350z, add, amp, bose, coupe, diy, g35, install, located, radio, remote, subwoofer, system, wire
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
