MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area - V35 > Audio, Video & Electronics
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Welcome to G35Driver.com!
Welcome to G35Driver.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today!
Thread Tools Rating: Thread Rating: 2 votes, 4.50 average. Display Modes
  #211
Old 06-16-2008, 02:57 AM
One question.
You used a direct RCA connection instead of a line out converter from the rear speaker lines.
Is that because of the balanced/unbalanced deal on the amp?
  #212
Old 06-16-2008, 08:51 AM
RCA connections are used when the audio signal is acquired from th OEM harness before the signal enters the Bose amp. That signal is already at line level (and a low line level at that) so no LOC is needed. It is better to tap into the signal before it enters the Bose amp.
If you tap into the audio signal after it leaves the Bose amp, then you need an LOC.
__________________
Sean
Florida G Club '03.5 Caribbean Blue 5at Sedan w/ a few mods, '04 Laser Red 6mt Coupe w/ more mods, 06 FX35 bone stock
  #213
Old 07-13-2008, 11:34 PM
Xet Xet is offline
Yikes so im a bit confused about the tapping into the signal wires.
I am trying to transfer my old system to the g and i have a full wiring kit from that. I would like to be able to reuse the rca cables from the kit. If I were to cut into my rca's at one side, there is a red and white plug in for left and right (not sure which is which). So with that I would hopefully find 2 wires in each and just attach them to either of the corresponding side wires from the connector?
I apologize for the confusing wording, I do have experience installing subwoofers but never had to deal with a stock bose headunit with no aux's.
  #214
Old 07-13-2008, 11:40 PM
infinus's Avatar
2005 Infiniti G35
Quote:
Yep thats right. I went to radioshack ans got some in-line splicers, made it a whole lot easier.
__________________
My work: infinusphoto.com
  #215
Old 07-14-2008, 12:13 AM
Xet Xet is offline
Quote:
Awesome thank you very much, hopefully ill have my sub in by the end of the week. (Still have to work tom and tues on the box)
Inline splicers? I'll look for those. I was originally going to use T-taps but I'll just go with what I see
  #216
Old 08-03-2008, 03:28 PM
2003 Infiniti G35 Coupe
Send a message via AIM to Laid GP
I used this DIY to install a JL Audio 12w3v1 and a Visonik amp in my 03 coupe yesterday. Thanks a million for the instructions, it made it SO MUCH EASIER than any install I've ever done before.
I do need to find a better enclosure - I just used a prefab box I already had and it takes up way too much space in the trunk. I like the look of the 4080 box but it only works for 10s from the looks of it. Any good enclosures out there for a 12" that are similar?
__________________
2009 Stryker Blue Pontiac G8 GT
  #217
Old 08-03-2008, 03:35 PM
To the original post. Is the bass loud in the front seat? Or is it just legit
  #218
Old 08-03-2008, 05:14 PM
infinus's Avatar
2005 Infiniti G35
I've been looking for one forever, nothing seems to work other than if you use a shallow sub.
__________________
  #219
Old 08-11-2008, 07:42 PM
thanks man just got doing the install following your instructions(i used different sub and amp) but the directions were great, sounds fine and i am completely happy. thanks again
__________________
2007 Black/Black g coupe. Premium, Sport, Ras, Navi, awesome
  #220
Old 08-12-2008, 12:26 AM
infinus's Avatar
2005 Infiniti G35
So up until now my system has worked fine, but recently I've been having a few problems.
1. I now sometimes get a popping noise from the sub when I turn on the car.
2. Sometimes (randomly) the sub will stop hitting, then when I turn down the music all the way i just hear it back there vibrating and thumping randomly, then I turn the stereo off and it still makes the same vibrating and random thumping sounds (with everything off) and will do that until it randomly decides to kick back in. Sometimes even if i turn off the car then turn it back on the sub does the same thing, then will randomly start working again.
Any ideas?
__________________
  #221
Old 08-12-2008, 08:56 AM
^ It sounds like your amp has problems.
__________________
Sean
  #222
Old 08-12-2008, 03:19 PM
infinus's Avatar
2005 Infiniti G35
Quote:
Could it be overheating? I have it hidden under the plastic thing on the sides of the spare tire.
__________________
  #223
Old 08-12-2008, 06:04 PM
It sounds like a short or bad ground. It could be something else.
__________________
Sean
  #224
Old 08-12-2008, 06:14 PM
nice writeup man, subscribed
__________________
06 CLK 500
  #225
Old 08-12-2008, 07:44 PM
infinus's Avatar
2005 Infiniti G35
It was a short, I found a black scorch mark, I've relocated the amp and so far everything is working fine.
__________________
Tags
06, 350z, add, amp, bose, coupe, diy, g35, install, located, radio, remote, subwoofer, system, wire
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
