| New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login |
| Register | Photo Gallery | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Garage | Vendor Directory |
| Welcome to G35Driver.com! |
Welcome to G35Driver.com. You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today! |
Thread Tools |
Display Modes |
#376
this will come in handy for me later......SUBSCRIBED! THNX
__________________
#377
Great write up... I ran into some problems and will address them incase others need it.
I used an install edge LOC which works great. I had it wired exactly as the OP had. I scraped the paint off the ground by the factory amp/bluetooth/XM Box. Used a bolt and a nut, but was getting an intermittent gound. A little more scraping fixed that problem. Once I had constant power at the amp I was getting no sound from the sub. I tried many thing but could not figure out the problem. This morning I decided to replace the plastic in line splicers with butt connectors, and everything works great. I suggest soldering or using the butt connectors instead of the quick and easy splice. It takes a little longer but provides a better connection. I am running a JL 500.1 with a 10W7 in a Zenclosure.
__________________
Blah, Blah, Blah... I need springs or cheap coil overs! Let me know if you have some... |
#378
bravo...very very good work
#379
How would this mod work with two 10's?
#380
It would work no different.
__________________
05' Laser Red - Gone... New car - 2005 Blue/Black STi |
#381
Great. I'd love to do this mod, but I'd be looking for more punch.
#382
hi, thanks for the write up man its great!
Im actually doing this tomorrow. i have everything i need folowing your instructions. the only thing i didnt do was have an rca converter which i couldnt find. Im going to tap in to the back speakers(6x9s) Question im not that audio savvy so sorry)Should i tap into them before they go into the bose amp or does it even matter?? ive read a couple of posts where people are sayin that tapping into the wires after the bose amp will somehow filter some bass out? That its better to tap into them before the amp. This is my setup: MTX tc4001 kicker 10" CompVR 07CVR104 dual coil thanks !!!!!!! |
#383
forgot to ask:
if i wanted to connect with the rca instead of using the rear speaker signal, could i just cut any regular RCA cable and connect it somehow to the speaker wires before they go into the amp? has anyone tried this succesfully? does the RCA converter have more than just 2 wires? thanks again |
#384
can anyone point me to a good wiring kit? i am lookin for an amp to push 2 w3 and without blowing the alternator.
#385
a JL 500/1 would be fine, I have one. It was running 2 JLw6v2's and worked great.
#386
im using a install edge LOC from best buy. I wired everything the same way, except im not getting any sound from my sub. I get power through my amp, though. i used those wire easy taps and for the brown wires. I just left them alone.
What am i doing wrong? here's a pic:
__________________
95 E36 M3 -RIP . 98 E36 M3 Supercharged - RIP . 2005 G35 Lakeshore Coupe |
#387
Quote:
__________________
Sean Florida G Club '03.5 Caribbean Blue 5at Sedan w/ a few mods, '04 Laser Red 6mt Coupe w/ more mods, 06 FX35 bone stock |
#388
so what am I suppose to do again? Im just lost and dont understand this part of the DIY
__________________
#389
Quote:
To make that more understandable, when you cut the RCA, you'll see the two copper wires in the RED and two copper wires in the WHITE. From the Red, you join the negative to pink and the positive to blue (once again this is for your right output amp). From the White, you join the negative to purple and the positive to teal (this should go into your left output amp).. And the remote is the blue/silver one. All the wires that need to be touched are on one side of the row. I forget if it was the top or bottom but if you see which wire to splice, thats the row you are going to use! Don't touch the other row at all ![]() I hope that wasn't too confusing. Get rid of the LOC and just do it this way.
__________________
EXELR8 |
#390
alright. I'll give this a try. to clarify. These are the same wires on the BLue Bose input connector right?
__________________
| Tags |
| 06, 350z, add, amp, bose, coupe, diy, g35, install, located, radio, remote, subwoofer, system, wire |
| Thread Tools | |
| Display Modes | Rate This Thread |
