MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area - V35 > Audio, Video & Electronics
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Welcome to G35Driver.com!
Welcome to G35Driver.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today!
Thread Tools Rating: Thread Rating: 2 votes, 4.50 average. Display Modes
  #61
Old 01-06-2007, 10:54 AM
They accept both inputs (Hi and Low). They used the low at first. And it just wasn't loud at all. Moderate at best. They then broke the low level plug and then used a Tsunami line level converter (I don't know if its adjustable) to fix it and it worked better. So they must be coming from pre amp now that I think about it. I think i messed up the first explanation, my bad. So ok, they used a line level converter post HD pre bose amp. So, I now get a strong signal to the amps.
I have 2 amps, both DUB Audio (I believe its Audiobahn) DUB Mag Audio DUB1004 100x4 and DUB Mag Audio DUB2802 1000x1. I have 2 10" Audiobahn 600w subs in a front ported bandpass box. I also have a Power Acoustik PCNC-2.0F cap. I have MB Quart in the doors.
I was beginning to think that my battery wasn't strong enough to push the amperage, or my alternator is weak. I've had 4 amps in my last Honda and never even saw even a slight power drop in lights or anything. Without a cap.
Thanks for your input guys. and I forgot to mention that your install
  #62
Old 01-07-2007, 12:55 PM
i just had mine installed....the only problem is my amp is always on whenever my car is on......so i called me installer for an on and off switch and he said it was a bad idea cuz whenever i hit the switch i ll hear a loud pop....but i dont always want me amp on
__________________
2004 twilight blue G35 coupe
  #63
Old 01-08-2007, 11:03 AM
The bose amp has a turn on lead.
__________________
Sean
Florida G Club '03.5 Caribbean Blue 5at Sedan w/ a few mods, '04 Laser Red 6mt Coupe w/ more mods, 06 FX35 bone stock
  #64
Old 01-08-2007, 05:27 PM
TOP-NOTCH DIY!! thank you, that setup is exactly what i want except i might go for the 250/1 and a 10W3
i will install it myself with this thread printed out and in my hands
__________________
06 6MT|Lakeshore/Stone|Prem|Aero|Nav|XM|HR y-pipe|High Power LEDs
  #65
Old 01-30-2007, 04:21 AM
bump
Wow this thread was hard to find! It's now 320 in the morning!
  #66
Old 01-30-2007, 04:23 AM
Quote:
what did you search for? try amp under seat bose?
  #67
Old 01-30-2007, 04:55 PM
Send a message via ICQ to tjlazer Send a message via MSN to tjlazer Send a message via Yahoo to tjlazer
? on wires
Got a question from the install pic. Just trying to get all the install in my head before I go tearing into my G. In the far left there is a telephone looking cord and a set of two wires, what are those?
Plus in the wiring pic I do not see the purple wire, was it not connected? I see 4 tapping connectors though.
Seems easy enough, nice writeup...
__________________
2006 G35 6MT Coupe, 19" OEM Wheels, Athens Blue, 05 Aero, Graphite interior, JWT POP, 1.1" drop on 350Z RS*R Down springs, Project Kics 15/20mm, 4080/SS Ref 500sx/10w6v2
  #68
Old 01-30-2007, 05:53 PM
The phone plug is likely the bass boost control line and the other is likely speaker leads.
__________________
Sean
  #69
Old 02-19-2007, 10:29 PM
Quote:
Originally Posted by caelric
Very nice work, and awesome write-up. Whenever I see a good write up like this, I wish I had done the same with my install. I've got a 10w6v2 in a 4080 box, with a 500/1 pushing it, same as you. I've got very different signal connections, due to the complete removal of the Bose amp on my setup, but I've got an 05 (with no bluetooth) so I could do that. Not sure what the solution for the 06'2 is.
Dave
so many questions... can anyone help? i'm working on a 2006 coupe, prem w/ bose.
Q1. will replacing the bose amp mess up bluetooth functionality??
Q2. is disabling the rear 6x9's after putting in a box pretty much consensus?
Q3. for the sub's amp's RCA inputs, you should only convert one pair of +/- to be converted, right? either Right or Left from the rear, right?
i eventually want to get to a 500/5 pushing aftermarket speakers and a sub
but what i can afford now is adding a 4080 being pushed by an amp from my old car. i'd rather avoid installation fees, but i'm finding i have no idea what i'm doing with this g!
  #70
Old 02-20-2007, 10:23 AM
I don't have this answer since my car doesn't have Bluetooth.
Yes, if you add a sub since that is what the 6x9's are supposed to be. I prefer to actually remove the 6x9's from the car altogether to allow more bass into the interior from the trunk, but you have to remove a lot of interior panels, so it may not be as feasable for you to do it, depending on your skill level.
that depends on the configuration capabilities of your amp. Tap into the signal wires BEFORE they go into the Bose amp.
__________________
Sean
  #71
Old 02-20-2007, 01:28 PM
Thanks Sean! i'm buying the ebay service manual ($5, looks like a pirated copy), i guess that will answer all my wiring questions... that SpeakerWire -> RCA was throwing me for a loop, but i did a bunch of research and think i got it all figured out!
thanks again man.
  #72
Old 02-20-2007, 01:54 PM
Hi-Tech_G's Avatar
Dream Big Achieve Greater
2004 Infiniti G35
Location: Pothole central and still ridin slammed...Beantown
Bumb for a nice write up!
__________________
VOID WARRANTYMy car sits like this /___\ and sneezes really loud...to my frenemies you know who you are....
  #73
Old 02-20-2007, 01:56 PM
O HELLA JDM's Avatar
2005 Infiniti G35
Send a message via AIM to O HELLA JDM
that **** looks hella neat...and theres still room... im about to do this when i run into money again...money is running away from me again haha
__________________
IONIC Official Sponsor of SDGz
Nismo / Advan / Project Kics / Impul / Data / Tein / VIS / Invidia
Install Projects
  #74
Old 02-20-2007, 03:29 PM
thanks again man.
Here is what I have put together from other posts on Driver.
Quote:
BOSE WIRING COLORS AND SPEAKER SIZES
Factory speaker harness wiring colors
Front Right + Gray/Silver
Front Right - Yellow/Silver
Front Left + Green/Silver
Front Left - Red/Silver
Rear Door Right + Brown/Silver
Rear Door Right - Black/Silver
Rear Door Left + Green/Yellow
Rear Door Left - Black/Yellow
Rear Deck Right + Blue/Red
Rear Deck Right - Blue/White
Rear Deck Left + Blue/Yellow
Rear Deck Left - White/Green
Head unit output colors
The (+) are all on the same side of the connector.
Head Output Front Right + Orange/Blue
Head Output Front Right - White/Blue
Head Output Front Left + White
Head Output Front Left - Orange
Head Output Rear Right + Blue
Head Output Rear Right - Pink
Head Output Rear Left + Teal
Head Output Rear Left - Purple
Remote Wire Light Blue/ Silver
BOSE SPEAKER SIZES
COUPE
The tweeters are exactly 5/8" deep and about 1-5/8" in diameter (at the largest point).
You don't have to take the whole door off to get to them to look (you would to disconnect the wires). Just pop off the clips that hold the black plastic panel down.
I also know that Infinity Kappa Perfect 6.1 tweeters fit, as do the tweeters from the MB Quart PCE 216 set.
With the lower door speakers, the stock measurements are: 6-3/8" in dia. with 2.5" of depth.
I think just about any 6.5" speaker will fit, but holes will have to be drilled (Roll up the window first) for any.
The rear side speakers are EXACTLY the same as the lower door speakers. Same part number and everything. Strangely there is no tweeter (or even a cone) on any speaker in the back. See my other thread about possible mounting depths. I made a spacer but there were other great ideas on how to mount better speakers back there.
The 6" X 9" speakers in the rear deck are: 6.5" X 9-3/16" and 3-3/8" deep. Again, I think any 6X9 will fit here.
These are all standard six openings and any install shop can easily do this. If you are doing it yourself, I recommend buying a new 3/16" or 1/8" titanium (for metal drilling, I used Bosch brand from Home Depot, a couple bucks) drill bit. Just drills alot easier through metal in the doors.
As for the screw hole dimensions... just drill. Infiniti uses a weird 3 hole set up for their 6.5" mid ranges that you won't ever match up exactly.
The tweeter will be held down by the stock metal bracket. If your new tweeters are a little loose in the bracket, wrap them in weather stripping or something similar.
The 6" X 9" speakers are standard mounts in the four "corners" of the speaker.
SEDAN
The fronts can fit the same 6 1/2 inch separates as the coupe. I thought the rear door speakers were 6 1/2 also, but they are smaller - perhaps 5 1/4 to 6 - which doesn't really matter because you'll have to make spacers anyway. My sedan has a pair of 6 1/2 coaxials in the door.
The sedans bith the Bose have an 8 inch sub. IMO, don't bother replacing it. Just get a bigger sub in the trunk.
__________________
Sean
  #75
Old 04-20-2007, 10:10 PM
I just got done installing an Eclipse amp and 10" sub following the instructions in this thread....man, what a difference! I was going to swap out the front door speakers, but the front stage is still pretty good.
Thanks to dr6 and gilley for the info.
__________________
DG 6MT Coupe // Brembo // JWT // Borla // 06 Projectors // Eibach-SPC // Hotchkis // Tein Z S-Techs // Z Tokicos // Eclipse Audio // Polarg // Redline // OEM 18s and 19s // AND YES, MY G IS REALLY THAT CLEAN
Tags
06, 350z, add, amp, bose, coupe, diy, g35, install, located, radio, remote, subwoofer, system, wire
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
