| New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login |
| Register | Photo Gallery | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Garage | Vendor Directory |
| Welcome to G35Driver.com! |
Welcome to G35Driver.com. You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today! |
Thread Tools | Rate Thread | Display Modes |
double din dash installed---pics
Long post, sorry....
Well i finally decided to install my double din, i was gonna wait till I got the other metal bracket but I couldnt stand it. Ended up not needing the other bracket so that will take off about 40$ off the price. No real issues other than some slight modification to the bracket, didnt have any problems with windows not working. Oh yeah I dont have NAV, dont know if I can help you guys that do. Remember to remove the CDs from the bose, I didnt and had to plug it back up after I removed it to get them, and DONT FORGET to set your air controls to both zones or youll be screwed. First of all, it sounds 1000% better, I cant believe how much of a difference it made, before there was static and some cutout at high volumes ( i had to go to 20+ to get enough volume to sound decent) but now 12 or 13 on my alpine 7995 mp3 player is well enough. Probably due to the 4V preouts and the alpine MX media expander, Its much cleaner and clearer, bose put out a distorted signal, and my JL components often sounded overpowered and rattled, now I can keep turning up and it just gets louder and clearer, man m getting goose bumps, and even my 6X9s sound terrific, and I can control my MP3 changer with my radio. With my time correction and EQ set, man does it sound good, gotta get my subs finished now. Now for installation. Sorry no pics except finished project. You have to take the dash apart, PITA, then remove the radio, air, bracket. Hard as hell unplugging everything because not much length. Remove the metal bracket from dash about 6 screws. Remove the radio/ac from bracket. If you swap dual zone buttons, you have to take off the circuitboard and remove the button, not difficult. Take out the nav/empty compartment in my case and swap it over. Remove the air ducts/swivel things and swap them over. The new AC Controller screws right in. My alpine (probably most units) bolted right up to the factory bolt holes in the bracket, so did the pocket. EXCEPT the pocket didnt come up as far as I wanted to the dash and alpine so I redrilled the holes to slide it forward. Then I had some ABS lying around so I filled in the gap between the radio and pocket with a small piece I superglued in, cant tell at all. Now for wiring, I had previously ran BAT and GRD from my battery into the dash for my FM Modulator so I used that, for Illumination I tapped into the factory radio harness for that, its a Red/Blue wire on the main harness, then for Accesory, I again tapped into the same harness this time a light green wire. I ran my RCAs under the rear seat, removed my center console and ran them under the carpet, under the console, up and behind the radio, along with my changer cable, and remote wire to my amps. I had to run a few other things, I kept my FM Mod for future DVD/TV mod. Thats about it. Now that the radio/AC/pocket/NAVcompartment/air ducts was all installed back on the bracket I had to wrestle it all back in. The hardest part of this whole thing was cramming all the wires and crap back into the hole, I had my Modulator, TV brain, 4V preout box, and the old radio/ac harness which is a bunch of wires. Plug in the RCA, radio harness, antanna, changer, DONT FORGET THE NEW AC PLUG. Then push it all back in and install things in the reverse order. Then sit back and drool like I did. Here are some pics. 2003.5 G35 Silver/Graphite 6MT Premium Coupe 19" Gunmetal TE37s & 275/30 Michelin Pilot Sports kg/mm supersport springs Alpine/JL Audio/Stinger double din, he-he-he 110158-Imga0152.jpg |
Re: double din dash installed
another angle
2003.5 G35 Silver/Graphite 6MT Premium Coupe 19" Gunmetal TE37s & 275/30 Michelin Pilot Sports kg/mm supersport springs Alpine/JL Audio/Stinger double din, he-he-he 110159-Imga0153.jpg |
front view, you can see the ABS i used directly underneath the radio, looks like it was meant to be there.
2003.5 G35 Silver/Graphite 6MT Premium Coupe 19" Gunmetal TE37s & 275/30 Michelin Pilot Sports kg/mm supersport springs Alpine/JL Audio/Stinger double din, he-he-he 110160-Imga0155.jpg |
so sad, no more Bose!
2003.5 G35 Silver/Graphite 6MT Premium Coupe 19" Gunmetal TE37s & 275/30 Michelin Pilot Sports kg/mm supersport springs Alpine/JL Audio/Stinger double din, he-he-he 110162-Imga0156.jpg |
Re: double din dash installed---pics
tig488,
great detail of the install. i guess everything work out for you. How much did you say the installation took you? BTW, now that you got it, are there anyway we can get it? I want to get it. Thanks. g35mt |
Awesome. Now for the question of the day. How do we get them?
TIG...man how do we get them? Im in dire neeed!
"Dont start none, won't be none" |
Oh yea, This is one of the reason's why I didn't get the preminum package and nav. Where and how much did you get your double din? I can't wait to put my Sony c-90 and audio control 4.1 in the double din. Does your steering wheel controls still work?
2003 G35 Coupe 6mt Diamond Graphite 1992 Jeep Cherokee Blk 5.5 RE lift /w 33s AIM= bkchang79 |
Looks awesome! Will you be divulging your source to get the parts?
Thanks amG35 2003 Silver Sedan |
yeah my contact is in japan, little bit of a time difference, im in the process of talking to him about selling these to the US or just if he can handle 100+ orders for this stuff.
2003.5 G35 Silver/Graphite 6MT Premium Coupe 19" Gunmetal TE37s & 275/30 Michelin Pilot Sports kg/mm supersport springs Alpine/JL Audio/Stinger double din, he-he-he |
Great work. Please keep us posted.
Take care. amG35 2003 Silver Sedan |
to make the wiring easier the aftermarket connector is the same one nissan has used since 95, the only difference is the placement of where the wires are. If adding amps you don't need to worry about the speaker connections so all you would need is the two power wires and the ground, just make sure to match up the correct wires when hooking the Headunit to the connector. the connector makes it easier than having to splice into the stock connector.
best ET: 14.730 @ 96.14mph
__________________
2003 5at Black Obsidian Sedan: Best ET 14.51 @ 97.75mph |
Just installed the same Alpine deck as Tig along with an Alpine MRV-F450 5 channel amp. The amp is powering my Boston Pro 6.5s up front and NX67 coaxials in the back. I Don't have a sub yet, but will be getting one soon. I can't believe how it sounds, very clear and loud. The SQ is amazing. I will post pics soon.
kg35,
so you have seen the light eh? well, i had the premuim crap for one week and the next week it goes. Anyway glad you like it. g35mt |
I have seen the light! The soundstage is amazing. I am glad I can finally put a good system in this car. I love how the Alpine amp sounds, powers my Boston's perfectly. A good deck makes a world of difference.
| Thread Tools | |
| Display Modes | Rate This Thread |
