MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area - V35 > Audio, Video & Electronics
New! Use your Facebook to securely log into this site, click logo to login
Welcome to G35Driver.com!
Welcome to G35Driver.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today!
Thread Tools Rate Thread Display Modes
Old 12-29-2006, 05:54 PM
hwa hwa is offline
Invisicord Install Tutorial
This is a tutorial for installation of the "Invisicord" that has been popularized largely in part by users of this forum. To the uninformed, the Invisicord is a home-made cord available for purchase at http://www.invisicord.com that allows for users with powered mirrors to hardwire their radar detectors with almost "plug-n-play" ease. The entire process is very simple, but the directions that come with the cord are not very concise. Below is a quick tutorial on installing the device.
*Note: Invisicord currently supports the following detectors:
Escort 8500, X50, 7500, 6800
Valentine V1
Beltronics 965, 995, RX55, RX65
Invisicord wiring diagram (comes with invisicord)
Invisicord wires:
Locate harness on back of mirror:
Push in tab of harness and slide it out:
Identify proper wires and their corresponding slots (pink+black = 12V, black = ground, red+black = unused for this installation); place Invisicord yellow wire in the SAME SLOT as the pink+black G35 Factory wire; place Invisicord black wire in the SAME SLOT as the black G35 Factory wire
Plug harness back into rear of mirror, attach the other end of the invisicord into your radar detector, and you're done
The following may not apply to you:
When I was fiddling with the G35 wiring harness, a black plastic piece securing the wires from the mirror to the internals of the vehicle came loose and fell. I just reattached this.
For those interested, the mounting used to secure my Passport Escort X50 to my mirror is "Mike's Mount." Email MIKE3348@adelphia.net and mention you are from G35driver.com for a possible discount.
__________________
'04 6MT
Old 12-30-2006, 09:50 AM
The sensors on the top of the radar detector is completely blocked by the mirror. Wouldn't this decrease the effectiveness of the device detecting radar behind you?
__________________
06' 350GT 6MT | 07' 3.6L CTS
Old 12-30-2006, 12:37 PM
Good write-up. One thing to add, to prevent the x50 from rubbing and bumping against the bottom of the mirror you can put a round piece of felt or rubber stopper between the detector and the mirror.
__________________
'05 DG/Stone 5AT Sedan * Premium, Sports & Nav * OEM Front Chin Spoiler * Clear Corners * Tint * ClearBra * Z Tube + Stillen CAI * MD 5/16" Spacer * HKS Muffler * Aluminum Pedals * Z Springs/Front, Coupe Springs/Rear * Stillen Sways * D-Specs * Coupe 19s * iPod Video + USA Spec PA11-NIS
Old 12-30-2006, 04:18 PM
hwa hwa is offline
Quote:
In the pictures, I had to bend the mirror downward and at an angle for adequate space for the install. When it was done and the mirror was properly aligned, there is actually a gap between the mirror and the sensors on the top of the detector. Whether or not this is sufficient for maximum detecting efficiency may be an issue...
Quote:
Thank you. And that is a very good idea. Right now I have a makeshift buffer I constructed out of ...a Starbucks napkin.
__________________
'04 6MT
Old 12-31-2006, 01:07 AM
Is there a web page to order "Mike's Mount", or is it just via email?
Old 12-31-2006, 01:22 AM
Just wanted to double check (I'm not near my G35 at this time, and haven't yet ordered the Invisicord) - if you leave the radar detector turned on, and then shut off the engine, is power to the detector turned off? How about if the radar detector is on, and the engine is off, but the ignition is in the ACC mode?
Thanks.
Old 12-31-2006, 01:52 AM
I have an 05. The radar detector turns on and off with the car. I never have to turn power off using the detector power switch. I believe when you are in accessory mode, the detector is on.
__________________
Old 12-31-2006, 02:05 PM
hwa hwa is offline
That is correct. If you follow the above steps, the detector will power on and off when the ignition is started or when the car is in ACC mode. I have heard some people speaking of the detector staying on all the time, so I am assuming they wired the inviscord into an incorrect slot(s).
Mike does have a website for his mount. I do not have it on me but you can snag it with a search.
__________________
'04 6MT
Old 12-31-2006, 10:33 PM
ive been unable to find this 'mikes mount' webpage. lots of references with a google search but no luck otherwise. id be interested in one for a V1.
Old 01-01-2007, 02:45 AM
Quote:
Just shoot him a PM or an email. His username is Mike3348 and his email address is MIKE3348@ADELPHIA.NET. He is very easy to deal with and provides great customer service.
__________________
Old 01-02-2007, 10:14 PM
is the a such device like the Invisicord for the Valentine1?
__________________
2006 Laser Red 6MT/Premium Package/Z-Tube/JWT PopCharger/Bat's overlays/Escort 8500/X50 w/ Invisicord and Mikes mount
Old 01-02-2007, 11:25 PM
Yes, the invisicord is made for both the X50 and V1. The username for the person that makes the invisicord is Teamspeed. Shoot him a PM and he will help you out.
__________________
Old 01-03-2007, 12:12 AM
Brian
Great writeup! In an effort to add to this great thread, I'm going to share my pics of my V1 setup with Invisicord.
With this setup (slightly to the left of my rearview, and below the tint line) I have no interference with either the front or rear sensors on the V1 - line of sight is good, and I never have to take my eyes off the road to look over to see the V1 display. I simply reach up to mute it when I'm driving by shopping areas, and I find this location to be ideal.
__________________
~Team 350Gz~
2005 Athens Blue A/T Coupe l Sport l Premium l Aero l GordGee 10-wire Grounding Kit l K&N l l Motordyne l KurumaZ l Impul Skirts l INGS +1l 2500k Yellow Fogs l
Quote:
Originally Posted by GeeWillikers
I have never humped a sheep. I've hit on a few, but I've never humped one.
Old 01-03-2007, 08:20 AM
SWEET! now I just gotta decide with radar detector to go with
__________________
Old 01-04-2007, 03:12 PM
dude, thanks so much for that write up, I was just about to PM teaminvis with quesitons, but now thanks again!
__________________
05 LS Coupe 6MT Nismo Stillen Ztube HKS FI Ichiba Volk BC SP Grill Projectors 5/16MD Samco
Tags
6800, 9500i, 995, beltronics, cord, diagram, escort, f150, install, intall, invisicord, mikes, mount, passport, power, wiring
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive -
Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
