Sub/Amp install
Old 05-24-2007, 09:59 PM
vince1128's Avatar
Sub/Amp install
how hard is it to do this in one of these cars?
Old 05-24-2007, 10:14 PM
ttrank's Avatar
Grocery getter
I have done a few.
It is not bad except for the deck install.
Old 05-25-2007, 09:57 AM
ron4row2's Avatar
It's very straight forward.
Old 05-25-2007, 10:50 AM
Hi-TechG35's Avatar
Location: Pothole Central and still ridin slammed...Boston
It's not that hard. You just have to have some patience and electrically inclined! What setup are you trying to run?
Old 05-25-2007, 02:19 PM
ttrank's Avatar
Grocery getter
Wire is very easy to run in the G as long as you are not trying to go into the doors. That is a PITA.
Old 05-29-2007, 03:08 AM
Vietnamezzboi's Avatar
its easy jst gotta get an hi/lo converter hook those up to ur speakers .. and get power from the battery to power ur amp and ground thats about it.
Old 06-05-2007, 03:54 PM
lancer's Avatar
weren't you just asking about how to do this in another thread?
A "high/low" converter is more correctly a LOC or line-out converter, which takes line-level signal (i.e. what is going to your speakers, probably the rears) and converts them into RCA "preamp" (low-level) output signals for the amp. This is only necessary if you still have the stock headunit... AudioControl probably has some good stuff for this sort of application, maybe an Epicenter or something of the like.
3000vr4tt
09-07-2015 12:48 AM
SilverG123
Engine - Electrical
09-04-2015 01:12 PM
Quick Reply: Sub/Amp install
