| New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login |
| Register | Photo Gallery | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Dealer Listings | Garage | Vendor Directory |
| Welcome to G35Driver.com! |
Welcome to G35Driver.com. You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today! |
Thread Tools | Rate Thread | Display Modes |
#31
ok thnx but what about the whole that ill have once i remove the factory navigation, what do i do with that ?
#32
Can't you just leave the factory navigation where it is? You don't have to remove it to install a DD HU.
But if you do want to remove the factory navigation screen and controls, you can order the pocket and lid to attach to the DD kit.
__________________
Sean Florida G Club '03.5 Caribbean Blue 5at Sedan w/ a few mods, '04 Laser Red 6mt Coupe w/ more mods, 06 FX35 bone stock |
#33
i have an old double din conversion guide that i found on my computer. i uploaded here if anyone needs it:
http://www.mediafire.com/?vnnjz92lz7y
__________________
bye bye '05 G35 coupe -> 2008 - BMW E93 335i - White/Red -6MT - Fully Loaded - 35% - M-Technik |
#34
__________________
Maintenance, modification, and repair services. Email me for info. info@infiniticare.com DIY Video Series: http://g35driver.com/forums/g35-seda...eo-series.html |
#35
Quote:
couple suggestions.... its important to really inform and show folks how that AC controller harness is tricky and temperamental to disconnect and reconnect. The reason being that an improperly reconnected AC harness can lead to the AC malfunctioining causing it to blow 80 degree air all the time. another thing to show that would've been nice would be the in-cabin sensor where that gets accidently jarred loose also causing the AC to malfunction. last thing would be to NOT lay that titanium dash finisher on a rough surface. Was that stool a soft surface? lol it looked rough. Lay a towel or foam mat down on the surface you are working on...the last thing you want is scratch that dash finisher you waited months for since it is on backorder across the world.... otherwise, good basic illustration video....good job! doc
#36
Quote:
![]() As for all these great comments, please go to the thread on infinitihelp.com http://x.infinitihelp.com/forum/show...2207#post12207 and leave your comments there for everyone who watches the video to see.
__________________
#37
Quote:
__________________
G35 M6 Coupe with Navigation |
#38
Quote:
__________________
#39
if a audio installer installed my dd hu wrong and didn't hook up my new deck to my stock bose amp....will the speakers still work??
also if they do work , they would just not be that loud correct??? reason I ask is today I just got in my car after getting everything all hooked up and max out my volume at 39 and it only sounds like its on 15 from my old stock 6cd changer bose deck...... what could cause this???
__________________
Shift_out of reverse |
#40
The new HU must be connected to the Bose amp if you hear sound. Since the volume level is low, there is something wrong with the way the HU is connected to the Bose amp. You would have to ask him that. You should also have him do it right.
__________________
#41
it was a cheap ebay hu also ...i wonder if thats why.....heres the link
ebay item number 130218604121 http://cgi.ebay.com/ebaymotors/ws/eB...218604121&rd=1
__________________
#42
Quote:
anything else could be wrong??? could it be the cheap hu i bought?
__________________
#43
There could be several things wrong, but since you didn't install it, you need to let the installer troubleshoot and fix it for you. You can't tell us what was done during the installation.
__________________
#44
the pdf was very helpful. probably would've ruined a few things without it. (though I still messed up a trim)
#45
Quote:
ok so I went back and told the owner and also a worker that has been there for years....he said they contacted metra (the makers of the dd kit) and they said to test the out put of the radio's rca's .....(most push between 2-4volts).....well my radio only has about 0.5- to maybe only 1 volt and they said that I need a LOC (line out converter) they also said they it needs to be a 4 channel but since that dont have them they were going to get 2 - 2channel conversters .....its actually made from PAC so hopefully not only will this clear up the horrible distortion i have but also raise the volume.....currently i'm maxxed out on volume at 39 and it sounds like how my stock did at only 15 (half as loud)....so hopefully my new deck will become louder and actually sound better
__________________
| Tags |
| 03, 2003, 2004, 2005, ac, controller, conversion, din, diy, double, g35, harness, install, kit, mod, scosche |
| Thread Tools | |
| Display Modes | Rate This Thread |
