MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area - V35 > Audio, Video & Electronics
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Welcome to G35Driver.com!
Welcome to G35Driver.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today!
Thread Tools Rate Thread Display Modes
  #76
Old 09-19-2009, 10:45 PM
blAk mAx's Avatar
I'm Rick James, bitch
2004 Infiniti G35 Coupe
nice work..i want to add a carputer to my ride...i hope to put the ac controller or radio in that gap between the 2 lcds
__________________
95 modded maxima , 04 G35 coupe -- ISIS true dual exhaust from enjuku racing, 20" MRR, 350z S-tech, Ichiba camber kit, V1, z-tube, pop charger, ground wires, batt cover, iphone
www.myspace.com/OrlandoG35club
  #77
Old 10-15-2009, 01:05 PM
Quote:
Originally Posted by Deftronix View Post
The console pieces are both modified OEM parts. The ash tray holder was filled in through a plastic welding process (simply melting plastic together) Then dremel/sanding to get the deck hole cut. On the upper piece I used part of the xenarc screen bezel and cut a hole in the OEM piece and plastic welded them together which allowed me to maintain the mounting points for the lcd to the bezel/housing.
Deftronix,
This looks great!
I have been planning out my carputer for a while now, and I just don't really like the stock navi location nor the double din location solution. I would like to try something like you have done, but I have a few questions. 1.) What equipment did you use to do the plastic welding (iron, speed tip, air, gas, etc.), and what welding plastic did you use (ABS rods, PP, etc.)? 2.) Any progress with the HVAC control app? I think going with the bigger touch screen, like you have, seems like the best solution, but I would like to know your experience working out the ventilation controls. I don't have the stock navi, so I am thinking about custom welding the controls into that position, but obviously the custom app would be ideal. I am an ASP.NET (C#) web developer, so let me know if I can help with the app, assuming you do not already have it created.
  #78
Old 10-15-2009, 01:58 PM
Send a message via AIM to ZXERT
Still stock but it sounds much better after putting 60sqft sound deadening in there and filled the rear quarter panels with insulation. I had a 13w7 running off a Zapco Reference 750 at one point but took it out for the sake of the computer and more importantly my back seat . I do plan on putting some DLS components in and a smaller sub. Possibly a 10w7
What did you use to fill the rear 1/4s?
And what kind of SD?
__________________
Quote:
Originally Posted by ninous26
I've just seen people take a screw driver and just punch the **** out of their cats
TB 6mt very customized( stock 18's)
  #79
Old 10-29-2009, 06:01 PM
Twinsen's Avatar
Very impressive build, but good lord, $3,000 in parts? That seems excessive. My build for my 3000GT VR-4 only cost me about $800 for the PC, VGA 7" in-dash monitor, cables, GPS receiver, and single-DIN radio. And that build was from about 3 or 4 years ago.
Tags
84, 840tsv, car, g35, high, housing, infiniti, lcd, oem, pc, res, screen, touch, touchscreen, xenarc
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
