| New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login |
| Register | Photo Gallery | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Garage | Vendor Directory |
| Welcome to G35Driver.com! |
Welcome to G35Driver.com. You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today! |
Thread Tools | Rate Thread | Display Modes |
#61
I tried putting a tape in and have not had the problem occur since then. The tape/or tape converter from a MP3 player has been in for about 2 weeks.
#62
which thing are you referring to on the bottom right side.. can you post pictures to indicate what it is?
anyone else any luck with what polishguy123 is proposing? Quote:
#63
pics plz!...mines been like this for 3 months!
#64
Im telling you guys i dont have pics sorry but that is the solution! that little thing that we wiggled which probably popped it back in place somehow controls the radio and ac. once back in everything became normal again.
#65
Hey, I have the same problem with the AC and stereo unit haven't been working for the last 5 days. After reading your post, I tried to punch the bottom right side of my stereo unit, i didn't even take out the head unit..i just simply punched several times on the stereo right "wall" and BINGO!! they are in full operating operating condition right now. (the climate control, ac panel, and Bose LCD).
#66
Guys, If i pull the fuse for the a/c (Don't know where it is, help!) will it cause anything else to stop working or cause any damage short term or long term?
only a temporary fix of course, until i have gathered all the necessary parts to do a DD conversion. |
#67
Polish Guy...are you for real???
#68
Quote:
#69
Quote:
__________________
2003.5 G35 Sedan, Stock.
#70
Stealership quoted me $900 for a new radio and $1000 for a new circuit board. LOL. filthy bastards, for $2k i could get a new factory 03 radio OR a sick DD set up with Navi/Touchscreen/Bluetooth/DVD + Probably a new exhaust system. What a bunch of twats at infiniti.
#71
Quote:
I'm going to try Radio Medics (they service Southern Ca) and see if they can fix the problem. They said they can fix my factory cd changer (no display, cd error, cannot eject cds, etc...) and my a/c controls (a/c is permanently on and inoperable). They quoted me a reasonable price for the repair and sounded experienced dealing with this specific problem. There is not much info on the internet or BBB with this company. Does anyone here have experience with them or with repairing their original HU cd changer, a/c problem. Please reply don.y2k@gmail.com I will respond back with my results! Thanks! |
#72
There is no fuse to turn the a/c off. You would need to disconnect the cable connected to the dryer unit which is directly behind the grill on the engine/radiator area. Or, you could disconnect the cable plugged into the air condition module located at the bottom of the engine driver side under the air intake hose. Disconnecting either of these cables will power off the a/c and reduce RPM. Both are not exactly easy to do and would require removal of minor little things but if your A/C is stuck on high, i would suggest preventing constant engine wear and tear due to the high RPM the a/c adds to the engine work load. Plus you can save a little gas while you decide what you want to do with your head unit (HU).
There are, however, 2 fuses which are 15A blue fuses under the steering wheel panel fuse box that are listed under "blower" which do cause the air whether it be cold or hot to blow out of the vents. Removing these fuses will stop any air flow, but will not turn off the A/C module running of the engines a/c belt. I had the audio circuit board crap out on me this past summer and my entire HU was dead and i had to suffer for about a month before i found an ebay seller who was able to make a modification to the board which permanently restored power of my radio/cd player/ stereo/ Air conditon/ defroster/ and steering function controls to the stereo. This is the guy who for a reasonable price fixed my stereo instead of me spendng the money on an aftermarket stereo. ebay seller name: xw1600 |
#73
The EASY Fix
Here's my report back.
Radio Medics solved the problem by repairing and beefing up my power supply to my original head unit to decrease the likelihood of a repeat problem . Everything appears to be working fine. CD changer, AC, Radio, and Satellite Radio all work fine. Fast, friendly, professional service. Rob came to my home and removed the unit and shipped out to their service center. A week later he returned and reinstalled my unit. Repair/parts/labor for approximately $300 and some change. Well worth it to keep and maintain the original factory look. I'm having him come back and install an iphone/ipod adapator for me. I am very happy. Thanks for the info supplied from this forum. Otherwise I'd be stuck having to deal with the Dealership that wanted $1800 and told me the unit was NOT repairable. ![]() Quote:
#74
Quote:
I live in Toronto, ON and got quotes of $270-$300 to remove the HU unit, replace the power unit and reinstall. Fixing the CD might be an additional $70-$100. A big difference from the $600 Infiniti price which was for a refurbished HU unit and circuit board. |
#75
Can you plz let me know the radio repair places in toronto you know.. I am gonna try them...
Quote:
| Tags |
| 03007, 2003, ac, canada, coupe, fuse, g35, infiniti, itb, itb03007, radio, reference, remove, reset, sedan |
| Thread Tools | |
| Display Modes | Rate This Thread |
