MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area - V35 > Audio, Video & Electronics
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Welcome to G35Driver.com!
Welcome to G35Driver.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today!
Thread Tools Rate Thread Display Modes
  #46
Old 06-15-2009, 09:02 PM
What gauge wire are you running?
__________________
04 OB Coupe 6MT * Kuruma Z * Impul * Seibon TS * Mastergrade MG2 * HKS * SPC * Tein * JL Audio *
  #47
Old 06-16-2009, 02:24 AM
Send a message via ICQ to Jamaica2G Send a message via AIM to Jamaica2G Send a message via MSN to Jamaica2G
1/0 with 150A fuse to the trunk... which has a Kinetik HC 600 and a 1/0 from that to the block that splits into two 4 GA wires. One 4 GA wire to each amp - the largest size you can fit into the amp.... The 1.1000 has an 80A fuse in the 4ga line. The 4.150 has a 60A fuse. Do you think I need a 100A fuse to the sub?
That's the only possible thing I can think of... cause as I type this I remember people saying they had to upgrade to 25A fuses on the 1000.1. lol now I can't remember if there are three or 4 fuses?!
EDIT: Methinks it 4 X 20A fuses in the amp.... soooo, I might be starving it that way. lol my poor electrical system hahaha. Damn that fuse is gonna be $10 hahaha
EDIT 2: so, I looked through my pictures and couldnt find a picture of the fuses that came with the amp... however, I DO remember the amp saying 20A on each fuse location... curiosity bothered me so much that I pulled apart a part of the system at 1AM to realize that it SAYS 20A but it came with 25A fuses! Since I didnt have a MAXI fuse that would push 100A, I hooked it up to the ANL with a 150A fuse... Think it'll get enough power NOW!? I put the MAXI 80A fuse on the mids and highs.
Tomorrow... Young Jeezy hahahaha
__________________
'05 LR 6MT "Mei-Ling"
Avatar: I always wanted to do that when I was younger. Wait a min, I still want to do that every day!
---+++---Adrian---+++---
  #48
Old 06-16-2009, 10:19 AM
FAIL!
It still cut out. I'll be hooking up the stinger Voltmeter to the batt in the trunk tonight.
Any other suggestions?
Adrian
__________________
  #49
Old 06-17-2009, 03:00 AM
Wow...
Now I am confused more than ever. Hooked up the voltmeter directly to the batt in the trunk.
At rest 12.6V
Start car 14.3V
So I head down the interstate bumpin some more young jeezy... The lowest voltage I can get it to go is 13.2V and its just for a quick second. After 40 seconds of hard work, the amp goes into protect. I don't think its a voltage problem.
Here's the weird part...
When it goes into protect, for the first 10-15 seconds, the voltage drops to 12.5V then goes back up to 14.1V when the amp quits suckin power.
What The Heck? I am very confused now.
The only things left that I can think of is... Impedance? But we know its set for the 2 ohm load... Two 1 ohm subs.. and we checked impedance before hookin it up.
Gains too high? It should be able to bump hard.... and I have it at about 70%
Adrian
__________________
  #50
Old 06-17-2009, 03:44 AM
FYI, I am running two 1 ohm subs in series to provide a 2 ohm load.
Im trying to think of anything that could be the problem...
Adrian
__________________
  #51
Old 10-06-2009, 10:23 PM
So when I measured my ohm loads, I never zeroed out my meter... The corrected measurements show that each sub has a resistance of 0.7ohm.... so even wired correctly, I'm below the 2 ohm requirement...
GAAAH! Time to send these subs back to have them wired differently.
__________________
  #52
Old 10-07-2009, 01:00 PM
2004 Infiniti G35
My Garage
out of curiosity why did you purchase 2 ohm subs? (I'm guessing they are dual voice coil)
those amps will push out the same amount of power at 2 ohm as they would at 4ohm. it's built into their circuitry.
The JL Slash series are the only other amps I know of that do that
__________________
Too many mods
  #53
Old 10-07-2009, 03:44 PM
pfarmer's Avatar
Keep in mind that impedance is not equal to resistance. Impedance is what the load will look like when loaded since it instantaneously changes with frequency. A speaker is rated at its nominal value.
For a full range speaker you could have an impedance of 5 times (or even higher) the nominal value at low frequency and at just a little higher frequency it could have less than the nominal value.
If you want to accurately measure the actual impedance you could put on a set of test tones the speaker will be operating at and measure the voltage and current flow to calculate it.
__________________
Eagles may soar but weasels don't get caught in jet engines
  #54
Old 10-08-2009, 10:06 PM
2004 INFINITI G35 Coupe
__________________
My Base Dyno Runs-->http://www.youtube.com/watch?v=jFhM8EwO3MQ
  #55
Old 10-12-2009, 03:30 PM
Troys:
They actually messed up.
They are dual voice coil subs that were supposed to be made to give me a 2 ohm or (1.4ohm) reading for each sub... so when wired up, they would show up at 4 ohm or (2.8 ohm) load...
They sent me the subs with them wired up at 1 ohm (0.7 ohm) load.... They are internally wired to avoid seeing wires in the trunk, so I def have to send them back.
PFarmer, when I play music and watch the meter, the impedance just goes up from the 1.4 ohm load. I havent seen it drop below the original number. I might be talking about something completely different from what you meant though
What's the equation to make the proper calculation?
__________________
  #56
Old 10-12-2009, 04:12 PM
pfarmer's Avatar
Troys:
If you are using a standard DMM meter and are measuring resistance you will most likely not get a good reading with the system in service. With it out of service you will be measuring resistance ( and disconnected) but the value will not give you an accurate impedance reading.
A test tone in the frequency range can be used to calculate it.
Basically resistance = voltage/current (dc circuit). The same equation can be used. Technically impedance is the 'resistance' to current flow. The difference is that in the case of something like a speaker it constantly changes.
I don't know what meter you may be using but there are some that can directly measure this in service, but it is easy enough to calculate it.
One factor that makes a speaker a little more complicated than simply a coil attached to the same place is when the speaker moves back to rest. Remember a speaker can be used as a mike (depends on the speaker), if the speaker is fully extended for example and then the current is removed it will move back to rest and generate its own current flow. When playing music it does the same thing. Because the moving coil has inductance, resistance, and capacitance it will act differently at different loads and frequencies. That is why the ohm rating is 'nominal'. Consider what occurs if the same load was presented and the voltage was increased - Power = Voltage (squared) / resistance (dc circuit). In an ac system power companies will increase or decrease voltage to make the load look different to the generating facilities. This works because the system has capacitance, resistance, and inductance. If it had only resistance than what would occur is an increase in power and therefore load although heat would increase the resistance.
A speaker will do the same thing, increase the temperature due to load (power output of the amp) and what will occur? What will occur if not limited in some fashion?
__________________
  #57
Old 10-16-2009, 01:31 AM
did you check that you have good grounds?
if the amp sees a lower impedance it would prob just go into protection mode but not blow fuses.
something is shorting in there causing fuses to pop.
it seems your speaker amp is working fine right? it's just your sub amp that keeps popping the fuse.
__________________
07 G35 Sedan + 18'' OEM wheels + Alpine 10'' TypeR & M500 amp + Boyo Vtl420
  #58
Old 10-16-2009, 04:29 AM
pfarmer's Avatar
One question and I haven't checked this out in the case of audio systems - did you replace with the correct type of fuse, that is FB or SB?
__________________
  #59
Old 10-17-2009, 01:12 AM
probably a bad ground...
__________________
97 VW GTI vr6 h&r•tokico•neuspeed strut bar•hella projectors•badgeless grill•stoptech BBK•schroth harnesses•momo wheel/knob/boot/pedals•neuspeed intake•TT exhaust w/flowmaster & high flow cat•spec clutch•fidanza flywheel•neuspeed/GIAC ECUs•busted a rod bearing so i bought an 04 CB coupe
Tags
03, 11000, alpine, audio, blow, blowing, fuse, fuses, g35, ohm, pdx, pdx11000, sedan, stereo, subs
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
