Post pics of your double din setup
on
1 Post
Originally Posted by 1 sick G
Thanks appreciate it..... what aftermarket harness do I need?
Oh yea and keep those dd pics coming
Nissan Antenna Adapter
If your doing the Install, here's a good DIY link.
http://www.autotalk.com/how-to/infin...o-install.html
Holla.
Originally Posted by HipHopPro
Scosche NN03 Wiring harness
Holla.
Holla.
Thanks. I have also seen a wire harness with rca cables on it for the g35 bose system. Do you know what this is. I want to hook a double din up and wire them to the factory bose speakers. Which of the two do I have to use. Thanks
Originally Posted by slvrg05
Here is mine:
I used the Metra 70-7550 (equivalent to the Scosche NN03 harness) to install my JVC Arsenal DD. Sounds good, but there is a barely audible whine at low volume levels. I am satisfied for the time being, but to alleviate the whine, I am going to install a Line Output Converter. If I had it to do over, I would have installed the LOC from the beginning. Hope that helps.
As for the other harness (with the RCA's). With this harness you use your preamp outputs on your DD instead of the speaker wires. This would be very useful if you plan to scrap the entire bose setup and run your speakers off of an aftermarket amp. This way you can run the RCA's straight to the aftermarket amp without having to deal with the bose at all. Only downside is you will have to run new speaker wires from the aftermarket amp to all of your speakers. This is what I plan to do this spring... it's just too cold and I don't have a heated garage/shop.
No way Parrot and Garmin are both best in the their game and both are in the Kenwood. I was on the Alpine bandwagon for the longest time but Kenwood owns all DD right now imo. Ive gone to Boston a bunch of times and the Navi was dead on. I have had some complaints on my bluetooth though but I think I have a bad unit. Im currently in a dispute with them and caught them in a major lie today...Its a long story.
When you gonna get DD Shane?
