MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area - V35 > Audio, Video & Electronics
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Welcome to G35Driver.com!
Welcome to G35Driver.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today!
Thread Tools Rate Thread Display Modes
Old 02-04-2009, 05:22 PM
07 G35 Sedan Factory Sirius Install Question
So I recently purchased the factory sat unit to replace my starmate that plugs into the RCA jacks and now I have 2 issues. The first is when I use the key fob to lock or unlock the doors their is no longer a horn beep and the lights do not flash. The second which is more disappointing to me is that the volume sucks! Before with the starmate the bass would shake the heck out of rearview mirror at low volume and now I turn it 3/4 of the way to full volume and it hardly moves. The unit I bought is the same as what is shown on Grubbs site. The unit itself came with 2 different instructions and I have searched this site and 6mt and see that the factory plug location can vary. I have removed all the panels in the trunk and I only see the 1 connector. It seems like simple plug and play. Why should there be any issues with the volume or alarm system? I have read about the Bose system compatibility but why should there be any problem plugging in the factory siruis unit?
Old 02-04-2009, 05:26 PM
2004 Infiniti G35
My Garage
do you have a link to or pictures of the connectors?
__________________
Too many mods
Old 02-04-2009, 05:32 PM
Oh good call! I will post a pic when I get home tonight.
Old 02-09-2009, 01:43 AM
Smile My Install
Here is my install, Plug was on the left side of trunk
07-g35-sedan-factory-sirius-install-question-siruis1.jpg   07-g35-sedan-factory-sirius-install-question-siruis-2.jpg
Old 02-09-2009, 10:06 AM
2004 Infiniti G35
My Garage
what's the unit to the right? looks like it could be the keyless module. Did you happen to unplug that? and can you unplug the sirius unit and plug it back in to where the plug initially was and have everything work again?
__________________
Too many mods
Old 02-11-2009, 05:41 PM
The unit you see to the right is part of the Bose system at least thats what it says underneath. There is a port for a plug but there was no plug in it. It looked just like that when I took the panel down. I have no idea what it is or what plugs into it. Could there be more than 1 plug for the Sirius?
Old 02-11-2009, 06:35 PM
2004 Infiniti G35
My Garage
honestly with that I could not tell you... does the sirius unit show up and work?
__________________
Too many mods
Old 03-15-2009, 03:51 AM
Send a message via MSN to Solid71
I did the same install 3 months ago. The end you used is on an extender cable. If you trace that cable it is connected to another cable. Disconnect the extender cable and use the end under the radio receiver. Use the double sided tape to mount the sat receiver under the regular radio receiver.
__________________
2007 G35 journey Serengenti Sand premium+sports package
Old 10-27-2009, 11:42 AM
I am interested in the same modification (replacing Starmate with OEM Sirius).
Did you ever get it to work ok? If so, would you mind documenting the steps you took? Were you able to use the existing shark-fin antenna?
Thanks!!!!
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
