| New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login |
| Register | Photo Gallery | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Garage | Vendor Directory |
| Welcome to G35Driver.com! |
Welcome to G35Driver.com. You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today! |
Thread Tools | Rate Thread | Display Modes |
or why don't you just carry a house key... or install a keycode unit on the garage... i think these are better options rather than opening that homelink housing/mirror housing and messing with the electronics
__________________
2008 G35x Premium/Navi - Silver || 2008 G35x Premium/Navi - Black || 2006 G35x - Black || 2009 G37xS Platinum/Graphite Prem/Nav |
Quote:
And my house keys are on my other set of keys for my other car that's parked outside. I guess I could make a copy, but I like the idea of the keycode.
__________________
'05 OB 6MT G35 Coupe
you could also purchase a proprietary garage door clicker for your brand garage door opener... ex: a genie garage door opening remote transmitter is like $45.00
Then open THIS genie transmitter and wire your auxilliary alarm wire to its circuitry and you'll have your alternate. The only thing is that you'll have to first program the clicker, then from time to time you'll have to replace the battery on this thing and keep this in a semi-concealed location.
__________________
Where's the DIY?
I asked the guy to send me the diagram of the layout or wires that he had.
I told him i would make a DIY but the guy never sent anything to me =/
__________________
PM me if you need any audio help or installation of a DD or single din, im glad to help
Here's what I got, let me know if you want me to email you a better copy. Now get started on that DIY!!!
![]() 2003 INFINITI G35 2DR COUPE Security WIRE COLOR POLARITY LOCATION Battery WHITE/BLUE (+) IGNITION SWITCH HARNESS Ignition 1 BLACK/RED (+) IGNITION SWITCH HARNESS Starter 1 WHITE/RED (+) IGNITION SWITCH HARNESS All Door Trigger WHITE (-) DRIVER'S KICK PANEL OR WHT 12 PIN PLUG AT BCM YOU MUST DIODE ISOLATE BOTH TRIGGERS TO MONITOR ALL DOORS. *SEE DOCUMENTS LF Latch WHITE (-) PIN 14 AT THE BCM ALSO YELLOW RF Latch PINK (-) PIN 10 AT THE BCM LR Latch PINK (-) PIN 11 AT THE BCM IF VEHICLE DOES NOT HAVE NAVAGATION USE PIN 11 IF VEHICLE HAS NAVAGATION, USE 2 SEPERATE PINK WIRES IN THE DRIVERS KICK PANEL IN HARNESS THAT RUNS TO THE REAR. DIODE ISOLATE ALL WIRES RR Latch PINK (-) PIN 11 AT THE BCM Trunk Trigger RED/WHITE (-) PIN 18 IN WHT PLUG AT BCM Hood Trigger LIGHT GREEN/BLACK (-) AT THE PIN IN THE ENGINE COMPARTMENT Alarm Disarm WORKS WITH THE LOCKS A SINGLE PULSE ON THE UNLOCK WIRE WILL DISARM THE ALARM WITHOUT UNLOCKING THE DOORS. Alarm Arm WORKS WITH THE LOCKS Parking Lights RED/BLUE (+) DRIVER'S KICK PANEL OR DIMMER SWITCH Convenience WIRE COLOR POLARITY LOCATION Headlights-Lo RED/BLACK (L) RED (R) (+) WHT 12 PIN PLUG AT THE IPDM MODULE IPDM MODULE - INTELLIGENT POWER DISTRIBUTION MODULE IPDM IS LOCATED BETWEEN THE PASS. FENDER AND THE BATTERY Wipers-Lo VIOLET (-) AT WIPER MOTOR Wipers-Hi BLUE/BLACK (-) AT WIPER MOTOR Parking Brake LIGHT GREEN/BLACK (-) AT THE PARKING BRAKE SWITCH Trunk Release PINK OR BLUE (-) DRIVER'S KICK PANEL OR PIN 76 IN BRN PLUG AT BCM Remote Start WIRE COLOR POLARITY LOCATION Battery WHITE/BLUE (+) IGNITION SWITCH HARNESS Ignition 1 BLACK/RED (+) IGNITION SWITCH HARNESS Accessory 1 WHITE/BLACK (+) IGNITION SWITCH HARNESS Starter 1 WHITE/RED (+) IGNITION SWITCH HARNESS Starter 2 WHITE/GREEN (+) IGNITION SWITCH HARNESS Anti-Theft Type IMMOBILIZER Anti-Theft Description TRANSPONDER THIS VEHICLE REQUIRES A TRANSPONDER BYPASS KIT TO REMOTELY START THE ENGINE. GO TO WWW.BYPASSMODULES.COM TO LOOK UP YOURS. ALL MODULES ARE AVAILABLE AT ALARMTEK AUTO SECURITY INLINE! Key Sense BLACK/PINK (+) AT STEERING COLUMN HARNESS Tachometer AT THE COIL USE NON COMMON COLOR (AC) DO NO USE WHITE/BLUE AND BLACK ALSO AT ECM MODULE PIN #23 Speed Sense WHITE/GREEN (AC) INST. CLUSTER AT BRN PLUG PIN 19 ALSO AT A/C & DISPLAY AMPLIFIER IN CENTER OF DASH Parking Lights RED/BLUE (+) DRIVER'S KICK PANEL OR DIMMER SWITCH Brake Lights PINK/BLUE (+) AT THE SWITCH ABOVE THE BRAKE PEDAL Reverse Lights VIOLET/ORANGE (+) DRIVERS SILL PLATE HARNESS MAY ALSO BE RED ON MANUAL TRANSMISSION VEHICLES Horn GREEN/BLACK (-) AT STEERING COLUMN HARNESS Modules WIRE LOCATION Module 1 BCM - BODY CONTROL MODULE IS LOCATED IN THE DRIVERS KICK PANEL Door locks/Windows WIRE COLOR POLARITY LOCATION Door Lock Circuit 3 WIRE NEGATIVE Power Unlock BLUE/WHITE (-) IN THE DRIVER'S DOOR AT DOOR CYLINDER SINGLE PULSE ON UNLOCK WILL DISARM WITHOUT UNLOCKING THE DOORS DOUBLE PULSE WILL UNLOCK THE DOORSALSO LIGHT BLUE AT THE DRIVERS DOOR MODULE ALSO LIGHT BLUE (-) IN THE DRIVERS DOOR MODULE. THESE WIRES ARE KEY CYLINDER WIRES Power Lock RED/WHITE (-) IN THE DRIVER'S DOOR AT DOOR CYLINDER ALSO YELLOW (-) AT THE DRIVERS DOOR MODULE. THESE WIRES ARE KEY CYLINDER WIRES Driver Mtr Unlock YELLOW (REV) PIN 30 IN WHT PLUG AT BCM Driver Mtr Lock VIOLET (REV) PIN 23 IN WHT PLUG AT BCM Pas Mtr Unlock WHITE/BLUE (REV) PIN 31 IN WHT PLUG AT BCM |
Sorry to bump up a really old thread, but I have a clifford matrix 50.5x and I'm attempting to wire the lock/unlock feature. I wired a green wire from the primary harness into the BCM (purple/red) wire I believe (domelight supervision) and that works fine. It detects when my door is open and such..
My issue is I tried wiring the door lock harness into .. Driver Mtr Unlock YELLOW (REV) PIN 30 IN WHT PLUG AT BCM Driver Mtr Lock VIOLET (REV) PIN 23 IN WHT PLUG AT BCM and I get no cigar. The alarm arms..disarms..sirens..but it wont lock or unlock. Any ideas?
__________________
Chuck norris drives a G35. :] |
You are looking for the wrong wires. I dont know what year car you have, but this if for an 03 like stated in the above post. These are the two wires you need to find..
Power Unlock BLUE/WHITE (-) IN THE DRIVER'S DOOR AT DOOR CYLINDER SINGLE PULSE ON UNLOCK WILL DISARM WITHOUT UNLOCKING THE DOORS DOUBLE PULSE WILL UNLOCK THE DOORSALSO LIGHT BLUE AT THE DRIVERS DOOR MODULE ALSO LIGHT BLUE (-) IN THE DRIVERS DOOR MODULE. THESE WIRES ARE KEY CYLINDER WIRES Power Lock RED/WHITE (-) IN THE DRIVER'S DOOR AT DOOR CYLINDER |
i am so sorry for the delay guys been really busy and havent kept up with any of my thread, i actually got fed up with the installation and took it out to a local dealer. Well if any of you guys are attempting to do this and need a extra blank transponder key let me know.
| Tags |
| 5901, alarm, break, ford, g35, idatalink, infiniti, installing, lightning, remote, start, starter, systems, viper, works |
| Thread Tools | |
| Display Modes | Rate This Thread |
