MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area - V35 > Audio, Video & Electronics
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Welcome to G35Driver.com!
Welcome to G35Driver.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today!
Thread Tools Rate Thread Display Modes
Old 03-18-2009, 04:21 PM
VIPER 5901 remote start alarm
hi guys, i just recently bought a VIPER ALARM with a remote start. i been searching around and asking alarm shops for labor and their charging me a grip just for labor, so this weekend i decided to install it myself. Quick question i know i have to purchase a TRANSPONDER bypass device but will i have to remove my stock factory alarm just to install this viper alarm i have? or i can just soilder my viper alarm right now with out removing any stock device. please advise thanks
Old 03-18-2009, 05:35 PM
I am looking at installing the same remote start...Everyone wants to charge an arm and a leg, so i am looking at doing it myself. Trying to do as much research as i can before i get into the install....kinda worried about not getting everything connected ( I have installed one in the past on a ford lightning, but i heard the Infinity is a bit hard). Keep us posted and take good notes
Old 03-18-2009, 06:24 PM
Quote:
We'll its not really hard cause i have all the diagram to install it, i just want to double check on the stock alarm system first before i make my first move too lol. Once i get everything wired up this weekend i will post up a DIY( if im not lazy) lol
Old 03-18-2009, 10:12 PM
2004 Infiniti G35
My Garage
you don't have to remove the stock alarm system just disarm it in which case you have to connect those wires anyways. if you have the wiring diagram you're fine
__________________
Too many mods
Old 03-18-2009, 11:39 PM
Quote:
www.the12volt.com
Kevin Pierson is an invaluable asset on that forum as he is on this one, and helped me COUNTLESS times on my r/s installs.
NO, i agree, you do NOT have remove your stock alarm system (I'd be impressed if you could figure out HOW to do so... )
The transponder/immobilizer bypass will allow the r/s to get the engine started, but the disarm/rearm outputs will allow your r/s brain to defeat (disarm) the stock alarm prior to starting the car so that it does not trigger the OEM alarm during remote starting.
Your unit will let your UNLOCK --> REMOTE START --> RE-LOCK ... as a programming option. With the 2003-06 G's .. you'll have to go through this sequence (i.e. enable this programming option) to disarm the factory alarm. I have this on my TL with my compustar r/s and it works fine. Some cars allow you to disarm the factory alarm WITHOUT unlocking the doors, but sadly, i haven't found a way to do this on the Infiniti's (2003-06 models).
I would recommends (highly) this product:
http://www.idatalink.com/store/index...ct_detail&p=68
as you won't have to go digging through your door panel to get at the lock/unlock wires --
best of luck -- go slow, test all wires with a DMM, and make sure you have a 6-pack of yer favvy beverage waiting for you in the fridge... you'll need it.
__________________
2008 G35x Premium/Navi - Silver || 2008 G35x Premium/Navi - Black || 2006 G35x - Black || 2009 G37xS Platinum/Graphite Prem/Nav
Old 03-19-2009, 03:23 AM
Quote:
Originally Posted by PeterUbers View Post
www.the12volt.com
thanks alot for the tip!! i will start this weekend..
Old 03-22-2009, 12:15 AM
I have that alarm installed in my 04 6mt coupe, had it installed "professionally" and i've taken it back at least 5 times. It still doesn't work correctly. It's a great alarm, but just make sure you wire everything right the first or at least the second time or you'll be really mad. It is a great alarm though and has many wonderful features.
Old 03-22-2009, 01:42 AM
usually, a remote start/alarm as reliable as it's installation....
__________________
Old 04-22-2009, 05:42 PM
Holliday's Avatar
MHE Mechanic, USAF
2003 Infiniti G35
diy
did you ever get around to making a DIY? I am going to put this in my G too. What interface module did you use?
__________________
Kinetix l injen l A'PEXi l DC l RAZO l R1 Racing l brembo l Stance l STOP()TECH l SPC l OBX
http://www.cardomain.com/ride/3318266
Old 04-22-2009, 08:30 PM
Vrod-Mike's Avatar
I do this stuff for a living and have for the past 20 years. There's a reason why good shops charge what they do for they're labor...... It's the knowledge they have that allows them to do the job right without doing damage to the alarm or even worse the car. Cars these days are not anywhere near as simple as they used to be. You spent good money on the alarm and you bought a moderately priced highend car so why would you not want to spend the money necessary to have the install done right?
Old 04-26-2009, 05:16 PM
Send a message via AIM to djCypher
the audiovox flcan data int. / transponder bypass part is the only one i would recommend using. the dei version seems to have alot of data collisions on the data wire causing the auto headlights to not always shut off like they should.
Old 04-26-2009, 07:00 PM
2004 Infiniti G35
My Garage
I don't trust anything from audiovox... intially it stopped with phones, then when they were making flipdowns and I had to replace half of them cuz the dvd stopped spinning. that's when I said no to audiovox
__________________
Too many mods
Old 04-26-2009, 09:40 PM
yup i tend to agree. the only thing i use from audiovox period is data flcan.
Old 04-29-2009, 06:21 AM
Dan's Avatar
Dan Dan is offline
Hmm, cool.
2005 Infiniti G35
My Garage
Send a message via AIM to Dan
Is there a way to program one of the aux functions on the remote to trigger the homelink button for the garage? Often times I don't drive my car and I only carry the key and remote with me so I end up locked out of my house.
__________________
'05
OB
6MT
G35 Coupe
Old 04-29-2009, 07:58 AM
Vrod-Mike's Avatar
Quote:
Not without opening up the mirror and soldering a wire right to the circuit that controls the buttons function, but if you have your car keys why can't you just unlock the car and hit the Homelink button?
Tags
5901, alarm, break, ford, g35, idatalink, infiniti, installing, lightning, remote, start, starter, systems, viper, works
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
