MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area - V35 > Audio, Video & Electronics
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Welcome to G35Driver.com!
Welcome to G35Driver.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today!
Thread Tools Rate Thread Display Modes
Old 06-08-2009, 01:37 AM
need help car wont start after sub installed
Hi guys i been stressing out like crazy trying to figure this out. ok i just bought this HIGH and LOw converter SCOSCHE SLC4
Photobucket
i connected this to the factory amp and the rca connect to my KENWOOD AMP and SUB, i removed my stock sub, everything works fine until like 10 mins or so the amp will turn off on me also my car will start but shuts off right away, i have to give it gas in order for it to start and idle right. whats going on? is it a bad amp?
Old 06-08-2009, 02:08 AM
Sounds like yer battery is dead -- have you been crankin' your new amp and sub with the car in ACC? How old is your battery?
__________________
2008 G35x Premium/Navi - Silver || 2008 G35x Premium/Navi - Black || 2006 G35x - Black || 2009 G37xS Platinum/Graphite Prem/Nav
Old 06-08-2009, 02:16 AM
is not the battery i replaced it brand new also it cant be the battery cause the radio and everything works fine just my sub cuts out and when i start my car it shuts off right away i have to give it gas inorder to drive it around
Old 06-08-2009, 02:21 AM
so you're drawing too much current from your alternator... you need a 2nd battery for audio application, possibly a capacitor.
Is your amp properly grounded? Where are you running the power from? Directly off the battery (that's where you should be grabbing power)
__________________
Old 06-08-2009, 02:23 AM
but my sub is only 400WATTS even though its 400 watts i still need a battery? by the way thanks alot for your help
Old 06-08-2009, 04:12 AM
Where are you grabbing your power from?
1) 12 volts directly off the battery?
2) Where did you ground your amplifier?
3) Are you sure there isn't a short in the amplifier somewhere between the battery and the amp -- that may manifest the symptoms your car is having
4) The fact that you need to gas it to keep the car running suggests that you're drawing TOO high a load and suggest a short circuit (power cable is touching something metalic on the car's chassis) and is not frying a fuse, but just draining the electrical system so bad that the engine can't even spark...
5) There is of course always the possibility there is something internally wrong with your amplifier (kenwood) but i would check your wiring first and rule that out as a possible short
Lemme know, happy to help
__________________
Old 06-08-2009, 02:07 PM
1) the 12 volts is connected to the batter
2) i ground my amp next to the spare tire but i make sure i sand it and to the metal then ground it
Old 06-08-2009, 02:38 PM
3) Have you checked the integrity of the power line running from the battery -- like no shorts (i.e. no places where the wire is pinched and connecting wire to metal BEFORE the amp)??
4) What gauge wire are you running from the battery?
5) Could you try another ground site?
6) Are you sure the amplifier and the subwoofer (the kenwood and the subwoofer) are connected properly?
__________________
Old 06-08-2009, 08:02 PM
Disconnect the amp at the battery and see if the car runs. Start eliminating things that could be the problem.
__________________
Sean
Florida G Club '03.5 Caribbean Blue 5at Sedan w/ a few mods, '04 Laser Red 6mt Coupe w/ more mods, 06 FX35 bone stock
Old 06-08-2009, 08:20 PM
^^ yea~!
__________________
It's G cruzin on basics bumpin JLz
Old 06-09-2009, 02:18 AM
ok guys, first of all thanks alot for your help guys. i got the sub up and running today everything works great but my car still wont run unless i give it some gas i thought it was my alternator so i disconnected my battery and reved up the engine. then i thought it could be the battery so i went to recharged it. still the car will start but it will shut off right away UNLESS i give it some gas then its drivable. what could be the problem?
Old 06-09-2009, 09:45 AM
Does the problem happen if you disconnect the amp power wire from the battery?
__________________
Sean
Old 06-09-2009, 02:10 PM
yes even though if i remove the amp power wire it still does that same thing but i will have to let the car sits for 1hr or 2 to start it back to normal, also i notice last night i turned off the radio and this morning when i start my car its fine
Old 06-09-2009, 07:52 PM
Did you remove the amp power wire from the battery or from the amp.
you never answered the question above (after asking it twice):
****>>>> did you check the entire amp power line from battery to amplifier (kenwood)?? ***<<<<<
Otherwise, you may have a bad alternator -- funny that it would crap out right after your added the sub -- maybe it drew just enough extra power to kill the alternator
__________________
Old 06-09-2009, 08:05 PM
i actually tried to remove everything and put it back to stock but its still the same so yes i did remove the amp wire from the battery and amp wire from the amp(KENWOOD)
Tags
amp, battery, car, cars, cord, gas, installed, kill, pinched, power, radio, running, spark, start, subwoofer, won, wont
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
