Please recommend a good remote starter/alarm installer in NJ/NY area
Old 08-26-2009, 11:16 AM
njchen24's Avatar
Greetings:
Could someone please recommend a good / excellent, after market remote starter / alarm (Python 991, Viper 5901) installer in the NJ / NY area?
Does anyone have any experience with or heard any of the following dealer / installer? Is there any good installer among them?
Viper Authorized dealer / Installer:
Main Street Electronics
226 Main Street
Orange, NJ 07050
Reliable Lock & Safe
17 Prospect Street
East Orange, NJ 07017
Sixth Avenue Elect
612 Route 10 West
Livingston, NJ 07039
System Addicts
727 Lyons Ave
Irvington, NJ 07111
Car Toys - Newark
426 Bloomfield Avenue
Newark, NJ 07107
Car Crafters
676 S 16Th Street
Newark, NJ 07103
Zippos Car Stereo - Belleville
745 Washington Ave
Belleville, NJ 07109
Car Toys
1521 Rt 22 W
Union, NJ 07083
Python Authorized dealer / installer:
RITE PRICE SOUND AND SECURITY
16 CLEVELAND STREET
ORANGE , NJ 07050
WHILE-U-WAIT CAR RADIO
227 BROAD ST
BLOOMFIELD , NJ 07003
CAR CRAFTERS
676 S 16TH STREET
NEWARK , NJ 07103
ULTIMATE AUDIO AND PERFORMANCE
681 KENNEDY BOULEVARD
BAYONNE , NJ 07002
AUDIO WAREHOUSE
170 GREGG STREET UNIT 3
LODI , NJ 07644
T&J ULTIMATE SOUND & SEC INC
1305A TRAVIS AVE
STATEN ISLAND , NY 10314
CAR CRAFTERS - RIVERDALE
90 ROUTE 23 NORTH
RIVERDALE , NJ 07457
MOBILE SOUND
9200 KENNEDY BLVD
NORTH BERGEN , NJ 07047
UNCLE STEVES
334 CANAL ST
NEW YORK , NY 10013
NEWEGG.COM - EDISON
45 PATRICK AVE WH14
EDISON , NJ 08837
M. ROTHMAN & COMPANY, INC.
50 WILLIAMS DRIVE
RAMSEY , NJ 07446
SECURELY YOURS, INC
1409 LOCUST AVENUE
BROOKLYN , NY 11230
SPEED WORLD, INC
77-20 QUEENS BLVD.
ELMHURST , NY 11373
PAGING CONCEPTS
236 E. RT 59
NANUET , NY 10954
SALTRONICS - YONKERS
124 SHERWOOD AVE
YONKERS , NY 10704
Thanks.
Old 08-26-2009, 12:36 PM
TroysG's Avatar
I'm not from the area but I've always heard good things about car toys shops
Old 08-31-2009, 05:09 PM
njchen24's Avatar
Thank you much for your input.
Old 09-01-2009, 10:59 AM
blklude98's Avatar
Unexpected Creations in Edison, NJ
his name is Don.
732-572-1969
If he doesn't pick up, leave him a message. He might be working on a car or something.
He recently installed my AVIC-F90BT with the tvandnav2go mod. He also did my alarm/remote start. He carries CLIFFORD..which is the same as Viper. He can get viper if you really want viper. If you are stick shift, he knows of a way to SAFELY do it using all the oem wires. Nissan/Infiniti's have built in neutral switches which makes this possible.
Jeff
Old 09-01-2009, 09:23 PM
KPierson's Avatar
Whoever you choose to do the install tell them up front that you want to see their work before they put the car back together - this little trick will typically get you a bit nicer of an install as 99.9% of customers don't think to inspect the work before taking the car from the shop.
When you take a look at the work, the main things to look for are:
no boxes should be easily visible from under the dash
all wires should be routed in a clean, OEM like manner
all connections should be securely made (I prefer soldering, but some people crimp)
General craftsmanship
Old 09-01-2009, 10:44 PM
thescreensavers's Avatar
Mr.202?
Lol why is newegg on the list? They are just a warehouse.
Old 09-14-2009, 08:22 PM
njchen24's Avatar
his name is Don.
732-572-1969
Jeff
Thank you so much for the info. I will give him a shout tomorrow.
Thank you for your good advice.
I will ask if I can take pictures of their work so I can recommend their shop if needs be.
Old 09-14-2009, 10:44 PM
Pearl05G's Avatar
Great points Kevin. You should also gimme a call about your products.
Old 09-14-2009, 10:47 PM
Pearl05G's Avatar
I look forward to the call and pictures are more than welcome.
Old 09-17-2009, 03:09 PM
pfarmer's Avatar
Due to many issue with remote starter installs damaging the BCM on cars with keyless ignitions I would ask for a warranty on the BCM. Probably will not get one.
Old 09-17-2009, 04:07 PM
Pearl05G's Avatar
This is simply due to a poor install. Done right nothing to the BCM or any other part of the vehicle is affected.
Old 09-18-2009, 03:38 AM
pfarmer's Avatar
Part of this depends on the use of a hidden key located in the vehicle or if one is completely bypassing the keyless ignition for a remote start. The starter relay is directly controlled from the BCM along with a few other items.
If you have a hidden key then the BCM gets involved since the key speaks to the BCM through the keyless receiver. Other things come into play such as the normal functions of not allowing you to lock your key in the car. If you don't have the key in the car then the BCM has to be told that everything is made up in the way of thinking a key is in the car.
Much of the rest is simple switch bypassing stuff but still is at the BCM, TCM level.
Old 09-18-2009, 08:45 AM
Pearl05G's Avatar
The key (RF portion) is in the vehicle, but not powered until remote start is activate. Same as being in the vehicle with it. No confusion for the BCM since it is never transmitting with the exception of start.
Like I said, failure would result from an inexperienced installer/poor install.
Old 09-18-2009, 11:51 AM
blklude98's Avatar
Don, you should probably say HOW you know this....BECAUSE YOU HAD A G Sedan with the Intelligent Key.
Minor detail...
Old 09-18-2009, 11:59 AM
Pearl05G's Avatar
Minor detail...
This is true Jeff, forgot about that part for a minute.
Jusseth
09-13-2020 12:25 PM
hdmark
04-29-2019 04:31 PM
Texasscout
07-24-2015 03:43 PM
EasySausage
07-14-2015 11:17 PM
Quick Reply: Please recommend a good remote starter/alarm installer in NJ/NY area
