MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area - V35 > Audio, Video & Electronics
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Welcome to G35Driver.com!
Welcome to G35Driver.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today!
Thread Tools Rate Thread Display Modes
Old 09-19-2009, 09:12 PM
alexbass311's Avatar
Speaker / Tweeter placement
Where have you guys put your speakers and tweeters in particular. Stock location or in the kick panels. Also, has anyone made mounts that alter the angle the speakers sit in the door so they don't face away from you?? I feel my system should sound better than it currently does and wondering if the positioning is the cause. I currently am running Focal K2Ps in the stock locations with a Pioneer Avic Z110bt and a JL 300/2.
__________________
2006 DG Coupe | PopCharger w/ Z-Tube and Clear Corners for now|Working on a SQ system....
Old 09-21-2009, 09:25 PM
different people like different things
optimal positioning would be mid and tweet close together.
If you are going to be daily driving i suggest adding about 5-7ft of wire to your existing tweeter and play with positioning.
Try factory, close to the mid, in the kick panel,etc
I like mine in the factory
__________________
PM me if you need any audio help or installation of a DD or single din, im glad to help
Old 09-22-2009, 01:14 AM
Thanks, any other opinions/advice. I would like to add that I currently have just replaced the front speakers and have not replaced the back. Have people had good luck / bad luck with this approach??
__________________
Old 09-23-2009, 05:20 PM
threatcon07's Avatar
Lex Sleuther
I am overhauling my system this weekend, one thing I am doing is putting my new tweeters in custom pods in the a-pillar, firing off axis. The midbass will stay in the stock location (door), with the door and door panel heavily dampened. Even in the stock locations, my current component system in front sounds pretty good (DLS UP6), but this new setup should sound even better. Have you had someone tune your system? That can make the biggest difference. If you are going for an SQ system, you will want to run a sub for the rear (no need for rear speakers)
Quote:
__________________
Rays Engineering/Stillen/Technosquare/Tanabe
Tokico/Federal Tire/Nismo/Muteki/DLS/Image Dynamics/Alpine/Cascade Audio/Corner 3 Garage/Simplicity in Sound/City Tire Online/Son Tran Wheel Repair/Prima/Menzerna/Chemical Guys-GLANCE
Tags
car, component, pillar, placement, speakers, tweeter
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
