Pioneer Avic-Z110bt in stock face
I have the wood trim, and have been going back and forth about wrapping the dash pieces with the carbon fiber look vinyl to keep the consistent look between the JDM piece and the wood, or cutting the stock dash to fit the new stereo.
Which way is better? Any recommendations to making the cutting option easier?
It's on my to-do list to create the vector drawings so you can just drop the file on a thumbdrive and have them cut it out for you, but I've been taking on a few other projects that have interfered with it, and it's a very infrequently request job, so it's been a low priority.
If you're handy with some vector drawing programs and want to whip something up for everyone else, the effort is always appreciated.
Urbanengineer (04-22-2015)
You can take it to most places that do laser engraving and cutting and have them cut it out for you. I've had a local place cut some thick ABS plastic trim for mounting a phone in the stock navigation screen location about a year ago, and it was, well, laser-perfect.
Unfortunately I am not handy with vector drawing programs, so I'm useless there.
Nylon 6, 30% Glass-Filled (PA6 GF30) - Akulon GF®
Polyamide 6 reinforced with the addition of 30% glass fibre and graphite. The glass charge makes the material highly resistant to abrasion, compression and flexing. Akulon GF is particularly suitable for gears and mechanical parts where excellent wear resistance is required.
I'm not sure if it is too much concern from various vendors; however the shape of the dash not producing straight cuts, the material and the potential for melting, if it'll even cut it, and the lack of extra pieces to test all give rise for concern.
Melting and the potential off gassing of harmful toxins seems to be the biggest concern.
Has it been successfully done by anyone? It would be a different discussion with the local vendors if that were the case.
http://www.laser-community.com/appli...plastics_4244/
http://www.ilt.fraunhofer.de/content...2/JB12_S67.pdf
The shape can be accounted for, just use some mounting putty to stick it to something flat and account for that in your cutting program.
I haven't heard of anyone doing the laser for our cars before, but a little research finds that laser cutting of PA6 is common -
www.laser-community.com/application/the-laser-meets-plastics_4244/
If they won't do it, there's got to be somebody with a machine shop with a milling machine (CNC not really required, it's straight cuts) that will. Cutting straight with a dremel is a fantastic feat.
Sometimes I wonder how businesses stay in business these days. It is as if they don't want money. I send e-mails to vendors and I get no answers from most. I guess follow up calls are needed these days. I just don't get it though.
"Hello, I have money and want to give it to you for services," I say.
Their reply, "...."
I'll keep trying. I found one vendor that has both a CNC machine, and a laser. They have the word "Plastics" in their name. But they can't seem to read e-mail I guess.
Their reply, "...."
#30
