MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area - V35 > Audio, Video & Electronics
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Welcome to G35Driver.com!
Welcome to G35Driver.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today!
Thread Tools Rate Thread Display Modes
Old 10-24-2009, 01:09 PM
Aftermarket Sub cuts out at higher volume
Not sure what has if anything I did wrong in this install. The case seems I followed the Bose install sticky for my MY09 G37x Sedan.
The Sub works till it gets to about 70% volume.
Things to note.
I have the HU bass setting turned down.
Have the tried high and low voltage input setting on the JL 500/1 Amp
Also turned the gain very far down as well.
When I adjust the all balance to come from only the left or right channel. The nothing cuts out and life is sort of good....
I have checked rechecked my connections make sure there are no frayed wires and all the cable inputs are on the correct polarities.
Any one have any suggestions. At this point I am for a loss...
Old 10-24-2009, 02:02 PM
Do you see any protection lights light up on the jl 500/1? If your subs are wired below 1.5 ohm, it will go into protection.
Old 10-24-2009, 02:13 PM
Quote:
Nope only light that is on is the Power LED. That also stays on the entire time.
Old 10-24-2009, 02:18 PM
can you check with a digital multimeter what resistance your sub is wired at? Just remove the speaker wire from the amp and put + + - - .
Old 10-24-2009, 02:27 PM
Also do you have a good ground to the amp? When you connected the ground to the chassis of the car, did you sand down the paint/primer around the bolt? Sometimes a bad ground can shut off the amp.
Old 10-24-2009, 02:37 PM
I attached it to the lower plate behind the seat and sanded it down to the bare metal before bolting the grounding block to it.
The part that has me is that when the chan is all left or right it works fine. Like I am getting to much voltage to the inputs. But from what I saw as long as I was tapping off the.
Blue and Pink and Teal and Purple lines I should not need to run it through a line out to preamp out converter.
Old 10-24-2009, 05:53 PM
2004 Infiniti G35
My Garage
Another thing you should note is that there is something called bass rolloff at ~70% max you lose the low end signals. couple remedies for this. A - wire to front speakers instead of rears. B - buy something like an MTX Re-Q, JL cleansweep etc
__________________
Too many mods
Tags
5001, amp, cuts, high, infinity, jl, volume
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
