MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area - V35 > Audio, Video & Electronics
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Welcome to G35Driver.com!
Welcome to G35Driver.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today!
Thread Tools Rate Thread Display Modes
Old 10-31-2009, 03:14 AM
Question Keyfob broken?
Hi guys,
The last 2 months my keyfob has been acting up. Sometimes it wouldn't work, other times it would. I did some searches and many people suggested radio interference, so I bought into it and called that the verdict. I drive many places (and far away) every day, so I don't necessarily think that's the reason, but it was my best explanation at the time.
Fast forward those 2 months, for the last week my keyfob has been absolutely not working at all. So I decide it's the keyfob battery, I take it out and put it to a voltmeter, reads exactly 3 volts (which is what the battery is rated at). I can't find my other keyfob to test if it's just that one or not, in fact I'm not sure if I received another one when I bought my car (new). Out of ideas, anyone have advice?
Car is 06 G35 Coupe 6MT.
Thank you!
Old 10-31-2009, 06:44 PM
pfarmer's Avatar
Quote:
Originally Posted by 2311 View Post
Hi guys,
Thank you!
So did you replace the battery anyway since it is what it does under load that counts?
Anyway what do you mean not work. That is when acting up does it unlock the car? I forget if it is a push button start or not (I think an 06 is).
In any case then there is an interference source that cause problems on some cars so I paid attention to this on my own when having problems and that is your cell phone. Try making sure it is always off when having problems.
On my car I am not sure if my issue is fixed which had to do with starting. A fob can get you into these cars but that doesn't mean it will allow you start one. So that is why I asked about unlocking the car.
Replace the battery and hope for the best. Buy from a high volume source such as Target, etc. to insure a fresh one. On mine I think the car will report the low battery with an ICON on the display.
On my car the IPDM was replaced, the BCM was replaced, as well as other items associated with starting the car. Not sure if it finally is fixed because of two none starts afterwards. One the day after the last fix (BCM) and one that I may have initiated (supposed to be an issue if certain buttons pressed at the same time on the fob, such as in your pocket).
Good luck you may need it.
__________________
Eagles may soar but weasels don't get caught in jet engines
Tags
06, 2008, battery, broken, car, coupe, fob, g35, icon, infiniti, key, keyfob, problem, replacing, working
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
