Aftermarket with OEM NAV?
Old 06-19-2010, 08:50 PM
spartan117's Avatar
I just came back from best buy and they told me if i want an aftermarket stero i would lose my built in NAV. Although they weren't 100% sure.
So if any one here could give me a definitive answer. I would only change my default stero if i can keep my gps navigation. So if it is possible what kit and other parts would i need.
Thanks for any help
Old 06-19-2010, 08:54 PM
gizmo134's Avatar
your nav will be there but there will be no sound without some homemade parts. everything else works though
Old 06-19-2010, 10:39 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Received 1,036 Likes on 609 Posts
spartan117's Avatar
Thank you for your quick response but what exactly would i need to get voice to work "home made parts". And i'm guessing i can just get a JDM kit and would have to buy the hvac controlls speartely as normal.
Old 06-19-2010, 11:16 PM
spartan117's Avatar
thanks for the link i googled the JDM 68260-7W000 since i have a 05 G35 sedan but i have a OEM Nav
"DM Double Din finisher plate for the 05-07 G35 Coupe. This piece allows you to add a double din head unit to your non-nav equipped Infiniti G35 Coupe." Source: http://www.envisionelite.com/Interio..._Finisher.html
Stupid question but could i still use it. If i can't can u recommend another one?
Old 06-20-2010, 12:10 AM
Hurt_Locker's Avatar
^ You would still need the AC controls, which they have there at that site on the related products. Save yourself the $10 and get the JDM kit from Riverside Infiniti as what Wratheraut has in his guide.
Old 06-20-2010, 07:57 AM
Originally Posted by spartan117
Stupid question but could i still use if i can't can u recomend another one?
Old 06-20-2010, 10:23 AM
spartan117's Avatar
Sorry the site that i mentioned states that JDM 68260-7W000 is for a non-nav.
"This piece allows you to add a double din head unit to your non-nav equipped Infiniti" So my question is if i can still use it. Since i have a navigation system.
Thanks,
Old 06-20-2010, 12:10 PM
It's been done before, it just needs a little motivation as you put it together.
Again, I'll be putting mine together (JDM + Stock Nav) in a few days (FLY TONIGHT!!!) and I can't promise high-quality, but I'll be videoing as much of the install as I can.
Old 06-21-2010, 09:01 AM
spartan117's Avatar
So i sent an e-mail to j's garage and found out there are two types of jdm dd kits.
68260-7W000 (double din w/o navi):18360yen
68260-7W010 (double din without radio a navigation):18360 yen
so i'm guessing i should just go with the second one right
Attached Thumbnails Aftermarket with OEM NAV?-2005alum-wnavi2.jpg   Aftermarket with OEM NAV?-2005alum-wnavi3.jpg
Old 06-21-2010, 01:57 PM
KillaMike's Avatar
Hey, I just got the Pioneer 4200-dvd put into my 06 coupe with factory nav, I got the JDM double din dash kit and my installer called me and said he can not put the navigation in with the new dvd deck because it won't fit. I went and checked it out and yes it was very tight, it took him a few hours but he got it to work, the only thing is the nav buttons are under the jdm dash kit a bit like it sits awkward but still kept my nav. You also gotta rip out this swede protector from the top of the nav buttons so the nav screen can go all the way down.....I will try to post pictures later. I had to coax my installer with a case of beer to complete this install took him 5 hours.
Old 06-21-2010, 06:20 PM
BacaraG35's Avatar
This is good news. Had no idea there were two kits. Was not interested in doing this because of the tight fitment issues. Now, hmmmmm...
Old 06-21-2010, 07:35 PM
Time to update the FAQ.
Old 06-22-2010, 08:58 AM
spartan117's Avatar
Well i actually ended up to going with th 7w000 becasue its alot cheaper i got the ac plus dd kit for $350 cdn. if i went with j's garage i would have to pay $665.00 cdn. I just hope it fits.
Old 06-22-2010, 10:31 PM
spartan117's Avatar
Another question if i do need to trim it (since im doing the install myself atleast im going to tryit) does anyone know what i would need and how i would go abuot triming the ddkit. Also almost forgot about
Originally Posted by gizmo134
your nav will be there but there will be no sound without some<b> homemade parts</b>. everything else works though
what homemade parts would i need to get sound to my nav.
Thanks
Quick Reply: Aftermarket with OEM NAV?
