| New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login |
| Register | Photo Gallery | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Garage | Vendor Directory |
| Welcome to G35Driver.com! |
Welcome to G35Driver.com. You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today! |
Thread Tools | Rate Thread | Display Modes |
#181
Is it hard to add a rear view camera and mod it to your navi screen? what all would i need? And For the NAVi screen to be able to play DVD how loong will it take to hook up a AV Electronics unit to the car? and where would i put it. and where would i find a AV Electronics unit at? hopefully someone can help me out.
Val
__________________
|| 06 Black 6MT G35Coupe/NAVI|||Illusion Lip|| |
#182
Quote:
Are you familiar with IPODs? Do they make an adapter to work with your device? |
#183
Quote:
Did you manage to solve your problems since you posted this? I'm thinking about buying the Gnet, but I can hardly find info and discussions anwhere! Thanks! |
#184
Hi
We have the interface if you need feel free to call us. Thanks Dominic Quote:
#185
Mod my G35 NAV
I am from canada and i had purchased the RBG unit for my G35 coupe. I was wondering if there is anyone in GTA area who has done this mod on there G35because i don't feel comfortable letting any audio shop do my mod for there first time. If someone has done this mod or if they know any good audio shops who can do this mod please help. Thanks in advance.
#186
So after reading, it looks like I can just use the KP Technologies Premier module for $50 to bypass the OK button on the NAV everytime I start it, be able to use NAV while driving, and be able to place in 1 device such as PS2.
Then I could get the PAC-AAI USA device to use Ipod, and get audio for PS2 while utilizing the CD Changer 5 & 6 slots. Does this sound right?
__________________
http://www.cardomain.com/ride/3073579 |
#187
No, KP Tech bypass unit only functions to bypass the OK button on Nav.
There's no video input!! You will need a TVandNav2Go or AV Electronics to get the video inputs. |
#188
That is correct, the KPtechnologies module has NO video converting abilities. What it will allow you to do is switch an external converter through the 'OK' button so you don't have to add a switch. It makes the integration very stock like.
The KPtechnologies module can also be set up to allow programming while the vehicle is in motion through the 'OK' button.
__________________
Kevin Pierson - Built APS TT 2004 DG 6 MT Coupe KPtechnologies is seeking resellers! If you can install car electronics and are looking to make some extra money let me know! |
#189
Quote:
__________________
#190
There is only one output, so you have to pick between the programming while moving or the control of the RGB converter of your choice.
If you want both, I would suggest using the KPtech unit for the programming while moving feature, as the output is 'smart' and will automatically switch the Navi system back to normal use when you quit programming it.
__________________
#191
I have finally completed my OEM Navi mods to play DVDs.
Check it out here
__________________
GM*GARAGE | 2006 G35 Coupe AT, LP, Navi, Premium/Sport, 19", CF Hood, Richie's Strut bar, Clear Sidemarker, TVandNav2Go, Navihack, Rearview camera
#192
Quote:
#193
Thanks! I've been enjoying the mod. Worth the money!
__________________
#194
So are there any other units out there or should I go ahead and get an AVElectronic one?
__________________
2006 IP Coupe - Stuff |
#195
Quote:
Check out mine My GPS mod is finally completed!
__________________
| Tags |
| 2003, 2006, bypass, converter, g35, interface, kp, nav, navandtvtogo, pac, rgb, sedan, tech, vcigm1 |
| Thread Tools | |
| Display Modes | Rate This Thread |
