MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area - V35 > Audio, Video & Electronics
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Welcome to G35Driver.com!
Welcome to G35Driver.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today!
Thread Tools Rate Thread Display Modes
  #61
Old 06-03-2005, 02:21 AM
of all the above, which has the best pic quality? from what i can gather, it seems navbox had the best pic quality since it give component signal, is this true??
  #62
Old 06-03-2005, 03:55 AM
Quote:
If you have an 03 or 04, they all give same quality. For 05, only AV Electronics unit works, still same quality...there is no such thing as a "better" quality.
  #63
Old 06-03-2005, 12:23 PM
I get how there is the RBG cable and they need to be cut, but what is the 4th cable (sync)?? If i were to conect rbg from DVD player, it only has the 3 cables, but on the navigator, there is the 4th cable that needs to be cut and I dont know what to connect to it.. does it make sense?
  #64
Old 06-03-2005, 01:26 PM
KPierson's Avatar
SPONSOR
Send a message via AIM to KPierson
There are multiple forms of an RGB hookup. Just because you have an RGB DVD player doesn't mean that it will work with our stock Navi. The most important factor is the type of RGB it is. Our stock screen uses an RGB + Sync signal, your DVD Player most likely uses an RGB signal that includes the sync information with the G signal.
I believe there are adapters that will extract the sync signal from the G wire and give you a sync signal to hook up. Without a sync signal you will not be able to get video data on the screen.
__________________
Kevin Pierson - Built APS TT 2004 DG 6 MT Coupe
KPtechnologies is seeking resellers! If you can install car electronics and are looking to make some extra money let me know!
  #65
Old 06-03-2005, 04:01 PM
How would I know where the sync signal is?? Where would I find such adapters and what are they called? Thanks for your help, very helpfull info
  #66
Old 06-03-2005, 04:08 PM
KPierson's Avatar
SPONSOR
In the 04 the sync wire is pink. You would have to do a search for a converter, I have no idea if they exist, but I think that they do. If they don't, they should!
__________________
  #67
Old 06-03-2005, 04:13 PM
There must be a way, since there is such a thing as a navbox that is taking component and splitting it to RGB and sync...
  #68
Old 06-03-2005, 04:23 PM
KPierson's Avatar
SPONSOR
actually, I believe the xbox native output signal is rgb with sync...
__________________
  #69
Old 06-03-2005, 04:40 PM
The component cables that I see (google search) for xbox are RBG and two RCA'
s for L/R sound. So 5 cable, 3 video and 2 sounds... Am I missing other cables?
  #70
Old 06-03-2005, 05:37 PM
I also believe it is RGB with sync, but sync is imbeded in one of the rgb's. I just gotta figure out how to split it
  #71
Old 06-03-2005, 06:08 PM
KPierson's Avatar
SPONSOR
http://www.gamesx.com/misctech/lm1881.htm
If this works, it would make it super easy to hook your xbox up... I may have to go buy an Xbox and check it out!
__________________
  #72
Old 06-03-2005, 06:23 PM
Rats, im behind a firewall at work and cant look up the site...
do you have the text? can you past on the forum?
  #73
Old 06-03-2005, 06:25 PM
LOL, actually, I was checking your link address and it seems to be pointing to something similar I was look at just now. LEt me send you the link:
http://www.national.com/pf/LM/LM1881.html
Also check this out, TONS of info:
http://www.xbox-linux.org/Xbox_VGA_HOWTO
  #74
Old 06-03-2005, 06:31 PM
another interesting finding is this site:
http://www.geocities.com/wonderer369/G35Nav.html
The guy set up a gex dvd player with RGB and somehow seperated the sync out, using the following method. Not sure if this would work on xbox:
"Using the one spool of Single shield audio wire from Radio shack, solder the pink wire that goes from the Display. Using the other spool, do the same to the pink sync wire that goes to the NAV. Route both wires to where the GEX Green and Red Connectors are. Connect the Nav Pink wire to the Red connector and the Display pink wire to the Green Connector.
Now you should have a total of 5 wires from the units infront to the GEX. You now have a total of 4 cables containing these wires. "
  #75
Old 06-17-2005, 06:09 PM
Anyone for Los Angeles are that wants to do it tigether. I really want to put the PS2 and Rear view camera on my 05 G Sedan. I am willin gto video tape the whole install and post it on the web. Email me if you are interested. msiwy@yahoo.com
Tags
2003, 2006, bypass, converter, g35, interface, kp, nav, navandtvtogo, pac, rgb, sedan, tech, vcigm1
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
