OBDII issues
OBDII issues
Hi
I have a 2003 G35 and i'm trying to connect to the OBD2 link. I can connect successfully with ECM,BCM, SRS etc but the OBDII connection keep failing
There is voltage on pin 6 and also check all fuse and everything is fine
Any idea what could be the culprit ?? I tried 2 different OBD2 cable btw
cheers
Thanks
cheers
Thanks
Hi
