A Couple Simple Questions From a New G Owner
Hey guys! So I just bought my 2005 infiniti g25 coupe sport with navigation system. I want to have an aux input to play my phone music in the car, Is the USA SPEC PA15-NIS THe thing i need for this? Will it fit with my nav system? Also, I was wondering if my throttle bodies should be cleaned, 106k miles and i dont think its been done. But my idle is right around 800-900 so is it even necessary? Lastly, my navigation system wont pop up when i press the button. It will go half up sometimes but then get stuck. I know this is a common problem, but what is the actual thing wrong with the system? what piece needs replacing? Thanks for everything in advance!
P.S. IF the TBs do need cleaning, Do you recommend i do it myself? I heard it is really risky and can ruin your motor if you mess up, but if not then can you link me to a good tutorial?
The PA15-NIS adapter fits just fine, it's an adapter with wires on both sides, so you can put it in several places, none of which would interfere with factory navigation.
Stuck navigation is usually dirty/ungreased rails for the pop-up screen. Follow the video I put together to get the navigation out to the rails to clean/regrease. Nothing needs replacement.
Radio cluster removal:
https://g35driver.com/forums/audio-v...urce-list.html
Nav removal video: https://g35driver.com/forums/audio-v...ment-info.html
You might want to split this question up to the appropriate forums.
Sweet, I will order the adapter now. And tomorrow i will check out your video and try to fix my rails. thank you.
