PA15-NIS Trouble, please help!
So, I have a 2005 g35 coupe and I jut installed the PA15-NIS, and It works and everything. The only thing is, when I drive it frequently cuts out and pauses, like the chord is falling out but it isn't. If I push it in really hard it will work for like 30 seconds and quit again... If you've ever owed an iPod or iPhone, it's like when you're charger starts to quit and you have to get it perfectly just for it to charge, that's what's happening. So, have any of you had this trouble? How'd you solve it? Do you know where I can find just the chord that goes from the radio to the iPhone, as that would probably fix it? Also, where can I find an RCA to mp3 chord to utilize that feature of the system? Thanks ahead of time!
I had PA15-NIS units in our '05 and '06 and they worked great. Which connector has gone wonky - from the radio to the USA Spec box or box to phone? Which end? Here's a box to phone cable only (out of stock though):
http://www.crutchfield.com/S-wnZLifT...b-pa105&tp=125
That's the one for the older iPods, 'Pads and 'Phones. If you have a newer model you should call Crutchfield and ask, I think you'd need an adaptor.
RCA to stereo mini works if you change the dip switches on the unit. You can get one of those cables anywhere - like Radio Shack, etc...
Sorry, don't know WTF happened to my link there?... Try again:
Or search for USA Spec CB-PA105. Maybe even on Amazon.
Hopefully replacing that cable will get you reliably reconnected.
SuperSaiyan
09-23-2015 06:13 PM
