OEM Stereo, volume sticks and some modes don't work
Hey All,
I've got an '03 Sedan, and find kind of odd. To start off, a little over a year ago I did the fix for the climate control/stereo and it's worked flawlessly since until now. So i've had experience pulling the thing apart and doing a repair, and the repair method shouldn't have damaged any other components unless they were directly nearby SMT parts.
The volume control, hitting the buttons will allow it to change volume up and down, but no actual volume adjustment happens. It'll still switch on/off when I go between 0 and 1 volume levels.
On top of that, the stereo's CD mode doesn't even work, the load, eject and CD buttons on the front do nothing. Switching to Radio has no output whatsoever, and the tape mode seems to spit out tapes often as if it detects the end of tape. (I've been using a tape for AUX).
It's seems from the behavior that there's another broken circuit that's making/breaking due to temperature since things will sometimes work fine. I'm hoping someone around here has some knowledge of the board layout, or even a circuit diagram for the board level electronics.
I don't want to replace the stereo with an aftermarket stereo. I know that'll fix the problem, but I don't want to invest that kind of money. Though I may be willing to buy someone's OEM unit if they have it laying around.
Anyone? Or even someone have similar issues?
I could pull the unit apart again and inspect the board, but it would be much easier if I found a circuit diagram. I did see one previously but I don't know if actually had the board level circuit or the assembly above it.
I don't know why I didn't think of this, several months ago the fusible link in my car flat out melted the cable connector on the 100A fuse rather than blowing the fuse, and may have damaged the unit.
It does look like this guy is alluding to the same problem though. He mentions the volume control working, but doesn't actually adjust the volume. I'm really at a loss though.
https://g35driver.com/forums/audio-v...und-radio.html
The circuit board diagram:
http://elektrotanya.com/clarion_pn24.../download.html
The page takes a minute to fully load, look for the part toward the bottom where it says:
"This file is downloadable free of charge: Processing" after a minute, "Get Manual" will appear where processing was.
Hydroshock (10-06-2014)
