Replaced 04 Radio with OEM Bose..Still problems.
I have an 04 G35 Sedan with 94k miles, recently the notorious radio failure happened to me. I got on ebay and was lucky enough to find just the radio and circuit control for $200.
Difference being that this radio/circuit is from a Bose equipped G35. It also had a Remanufactured sticker on it, so Im thinking the board was replaced under warranty.
I installed it yesterday, everything works..A/C controls, Radio, CD, Tape, RDS etc..But the audio is poor quality. It is no where near what my stock non-Bose speakers sounded like. Scratchy, Tinny, No real bass.
Also the volume is way off, at 24 it sounds like my old stereo at 14. All the way up at 31 it sounds quite scratchy. My speakers were just fine before this install. It also sounds this way with a CD, so I've ruled out the antenna being the culprit.
I'm wondering if the fact that I don't have the Bose amplifier/subwoofer, and just the Bose radio/control circuit in an otherwise Non-Bose car is causing this problem??
I should also note that there was an addition of a Dual Zone control button, which obviously doesnt work, and my clock was not illuminated last night.
I replaced all the fuses today just to rule it out, the 10 and 15 Amp ones in the driver's side compartment.
I'm at a loss and really don't want to have to go the double din route since Ive already spent 200 on this. Any help is appreciated, thanks!!
The bose uses an external amplifier, without that, you're not going to get any power to the speakers. I'm surprised it's even audible. Adding to the power level problems, the bose headunit outputs a differential-balanced audio signal - read more about that here: https://g35driver.com/forums/audio-v...-stock-hu.html
I can't say if the radio is related to the clock light going out, but if you've got one from a different year (03 vs 04) I could see the illumination being different enough to cause the problem.
Even if you picked up the bose amp, you still have none of the wiring to support it, so you can either try and return that HU to the seller (good luck) or just try and sell it and get a non-bose HU, or even better, put an aftermarket unit in there. Any 04 radio is going to be just as old, and just as close to failure as your old one.
Yeah, asking some basic questions in this forum would have saved you $200 and some time.
I understand there's no wiring in place for the amp and sub, but couldn't this be done? If I get the oem bose amp and sub or a comparable amp and sub, couldn't I wire that in?
I'm thinking of the most cost effective route, if I can buy the amp and sub and wire it in that would be cheaper than buying the Metra Kit and double din. Unless I can find a non bose unit.
Yes, I should have asked first. But I saw how much the units usually go for that include the trim on eBay, $400+, so I jumped on this one.
Instead, you could get a small JL audio 4-channel amplifier (like this), since they're capable of taking the differential-balanced signal from the bose unit. Mount it under the passenger seat, extend the audio wires to and from it, and run new 8-gauge power wires. Total cost is about $130-150.
Total cost including the headunit you bought, is $350.
The metrakit runs about $170, while a good (non-touchscreen) double-din unit with more capability than the factory unit can be had for $110 from pioneer. Throw in the steering wheel control unit ($40) and a wiring harness ($10) and antenna adapter ($10), and you're up to $340.
So, you're at essentially the same price, but the pioneer unit gives you bluetooth calls and audio streaming capability, PLUS, it's not a decade old refurbished unit.
Sell the factory units for whatever you can get and go aftermarket.
I just bought this alpine 4-channel (45x4, but that's real power not peak)
http://www.alpine-usa.com/product/view/ktp-445u
Its waaayyy more than I need, super compact, gets great reviews and I see some going for $70 used on eBay (or $149 new at best buy. Either way its a good price for 4 channels). Can't go wrong.
At 1/4 volume my stereo is almost unlistenably loud now and I don't have any sub's or anything. Sounds great and is super clear.
Its a little bigger than a Jawbone Jambox too, so you can put it pretty much anywhere.
bTanz
10-15-2015 02:31 PM
