is it okay to run speaker wires next to amp power wire?
So I have a 4 ga amp wire running along side the passenger side of the car to the trunk. I am reading a bunch that running speaker wires next to the power wire can cause a lot of noise. Is this true? should I not be running and zip tying my speaker wires to the power wire?
What would be the alternative? run all the speaker wires to the driver side and bring them back that way? Is anyone actually running it like that? or is it fine next to amp power? The power wire is a jl cable and heavily shielded if that matters
So I have a 4 ga amp wire running along side the passenger side of the car to the trunk. I am reading a bunch that running speaker wires next to the power wire can cause a lot of noise. Is this true? should I not be running and zip tying my speaker wires to the power wire? What would be the alternative? run all the speaker wires to the driver side and bring them back that way? Is anyone actually running it like that? or is it fine next to amp power? The power wire is a jl cable and heavily shielded if that matters
Don't tin it. The copper of the wires is a better conductor.
Urbanengineer (02-28-2015)
A wire untouched Should not be an issue. It's when things get tugged.
.cakestar (03-01-2015)
Wire the low gauge wire in a way that it pushes itself in with the weight of the wire. Mine were routed like a U such that the wires came up from under and pushed in with the force of the loop if that makes sense.
