2006 G35 coupe aftermarket sub/amp install?
I am just curious with my coupe if I would need to replace the stock HU? I read through a older users guide on here for his sedan, and he wired a LOC to the stock sub or something, and then wired the new sub/amp with the current bose amp, and then ran a group/power cable. How exactly is this done what is the process is there already a guide and I just missed it :P?
You missed it. It's sticky'd even.
https://g35driver.com/forums/audio-v...g35-coupe.html
If you don't have the bose setup, a LOC attached to one of the rear side speakers will get you the audio signal, while the amp's remote wire can be connected to the cigarette lighter socket in the center armrest.
Urbanengineer (07-21-2015)
I read the sticky, so for the amp rca they hook into the loc that comes out of the Bose sub, and then the remote goes where? More or less I'm getting a rock Ford punch sealed with a 500watt alpine. Also do I just leave the Bose sub wire unhooked after I use it to loc?
Power and ground, yep.
For parts-to-price that are pretty good, this list is pretty solid:
https://www.reddit.com/r/CarAV/comme...ort=confidence
https://g35driver.com/forums/audio-v...m-gallery.html
Would this LOC work for a Kicker 12" with a 500w alpine,
Would this LOC work for a Kicker 12" with a 500w alpine, http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER
laksjd84
07-24-2015 05:12 PM
