E-SKY Backup Camera Installation Help
Old 11-24-2015, 09:01 PM
hockeyguy215's Avatar
Hello all. Does anyone have a link or guidance with installation? It seems pretty simple, but could some input. Does anyone know which wire triggers the camera power when put into reverse? Thanks!
Old 11-24-2015, 11:15 PM
DeafBringer's Avatar
2nd picture in this specific post: https://g35driver.com/forums/audio-v...ml#post5036315
Please do a search next time. This is well covered. Welcome to the forum btw.
Old 11-26-2015, 09:23 AM
I couldn't find it anywhere. Maybe i was searching in the wrong spot. google search?
Thanks!
Old 11-26-2015, 10:37 AM
Well I am confused. There is a wire coming out of the harness of my pioneer 4100NEX that is labeled reverse. Where do I hook this up to? To the wire shown in the diagram by wrathernaut? Please elaborate. I am simple, so I need step by step instructions!! lol. sorry!!
Old 11-26-2015, 07:10 PM
Yes, the reverse signal wire on your Pioneer is spliced into the purple wire (coupe) or orange wire (sedan) that is show in the picture. Don't over think it. Use the pictured wiring diagram to guide you. Are you using a harness?
Old 11-27-2015, 12:23 AM
So i have the backup camera.
Backup Camera connections:
1 yellow video output > video input of pioneer?
1 red power > goes to the purple wire in the diagram?
1 black ground> ground obviously
Pioneer outputs:
Purple back up camera line> goes to purple wire in the diagram also
Old 11-27-2015, 07:07 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Received 1,036 Likes on 609 Posts
Pioneer outputs:
Yes
No. That's a power SIGNAL wire, not to power the camera. You can use the reverse light power wire to power the camera. You can generally use the reverse light as a signal wire too, if you want.
Yes
Yes
Old 11-29-2015, 12:17 AM
Originally Posted by Wrathernaut
Yes
Yes
Yes
OK-Did that
I hooked the camera red line up to 12V accessory? Camera powers on, but doesn't do anything when I put it in reverse?
OK-Did that
OK-Did that
Old 11-29-2015, 01:37 AM
Be sure you tapped into the correct purple wire in the driver side kick panel. You'll need to make sure you are looking at the correct bunch of wires. Look at the picture and you'll see a white tag on the correct bundle of wires to look at. Use that as your guide.
Old 11-29-2015, 04:39 PM
There are many purple wires, at least 4 different. Can someone please describe exactly how this purple wire is coded.
RemmyZero
V36 Audio, Video & Electronics
01-10-2016 03:18 PM
TheIronYuppy
11-23-2015 12:22 AM
Gage Pagano
11-20-2015 02:52 PM
akachi
Not G35 Related
11-08-2015 10:59 PM
youngdip631
11-02-2015 08:24 AM
Quick Reply: E-SKY Backup Camera Installation Help
