2004 coupe rear deck issue
Old 09-30-2016, 05:13 PM
Air_Infiniti's Avatar
Hey guys so for the past couple weeks I've been experiencing an issue with my rear deck where the 6 x 9 subs are. Whenever I am driving and my rpm go between 1500-2500 I hear a constant static noice until I get out of this range. The problem started happening once in a while before however now it has become more frequent.
About my setup: i have a 2004 g35 coupe with about 204km everything in the car is stock except the deck which I swapped for a jvc double din ( couple years ago )and the rear deck subs are hooked onto a separate amp but it is not tuned to high. I also changed the exhaust about 2 years ago but I don't think that would be impacting it (I could be wrong).
I tried looking online however was not able to find a solution that works. I tried changing the position of the ground cable which alot people mentioned but that did not work.
Any advice will be helpful I'm really getting tired of this noise.
HypeVqs
02-19-2017 12:33 PM
Troo
07-13-2016 12:37 AM
Siciliang35
07-10-2016 07:46 PM
raeyang
07-07-2016 02:08 AM
_Ghost_G35
07-06-2016 06:30 PM
Quick Reply: 2004 coupe rear deck issue
