Clime control color code
I am trying to understand how to re-write a custom board of my climate control, I understand RED and BLACK are the main power, but what about the other cables? What do they do?
Are they Serial communication to a main controller? I can see there is a chip MB90583CA and seems like two cables are used to send data via Serial.
Best help you're going to get without access to the full circuit diagram is the service manual - http://psedog.com/cars/fsm/g35/coupe/2006/atc.pdf
Starting about page 33.
Urbanengineer (11-24-2016)
Triggering an aftermarket Metra climate control is a much simpler process - and one I'll be doing again for a board member here for a total custom interior they're doing. The big problems I had doing it the first time was in trying to re-use the cut-off climate control portion, which has a lot of hidden connections throughout the circuit board. This time I'm re-creating that board from a blank one so the only connections there are the ones I make.
You might be interested in the "frankenboard" project build log, the juicy parts start here: https://g35driver.com/forums/audio-v...-dd-kit-2.html
If you use the metra climate board, it's two momentary pushbuttons. If you're using the OEM board or JDM climate control, I would recommend extending the wires from the OEM rotary encoder and just using it in whatever custom board you create.
