Frustrated - OEM nav not working after DD install
Can't find the answer or figure out the problem - Nav not workng after DD install, pioneer avh 2700 bs, metra 75-7550, Kicker ix1000.5 amp, Hertz components, kicker solobaric 10l7.
Cut trim to fit DD, no JD metra dash kit, no current working ac controller.
HU works fine except it's tempermetal with DVD/CD's.
Hear 3 beeps after IGN on. Nav screen doesn't come on, DVD ROM will not eject
I've checked all the fuses, wiring seems so don't know if I'm missing something the wiring - connections with the metra harnesses etc.
Off topic: anyone have recommendations for the front control arms bushing issues? My bushings are shot, thinking about the bushings kit from energy suspension vs. replacing g the lower control arms which would include new bushings and ball joints and/or coil spring/strut replacement?
Thank you.
Thank you.
Thank you for your response. The Nav is grounded same way it was originally, but will double check with meter. Metra is installed as per Wrathernaut's DD post instructions. The hu is working and I had no issues with the Nav before the DD install so I didn't think it was defective hardware. The harness for the Nav screen and switch is inserted, there's no open wiring and all the fuses are OK so I don't think there's a short.
The three beebs when the ignition is turned on indicated that the nav is not getting power per the manual so I initially suspected a fuse. I studied the wiring diagrams in the manual thinking that there must be some additional/alternative wiring required via the metra as the factory hu has been removed, but if that's the issue I can't figure it out.
Anyone have the same issue or are familiar with what may be necessary to supply power to the Nav when installing the metra 75-7550 with a DD and removing the factory hu?
Thanks.
Thanks.
on
You did not mention the year and model
https://www.sonicelectronix.com/item...a-70-7550.html
I do not see G35 or G37 listed
Compatibility List:
Infiniti:
1991 - 2002 G20
1996 - 2001 I30
1990 - 2002 Q45
1997 - 2002 QX4
Telcoman
Compatibility List:
Infiniti:
1991 - 2002 G20
1996 - 2001 I30
1990 - 2002 Q45
1997 - 2002 QX4
Telcoman
I apologize, I used the 70-7550, not the 75-7550
2003 g35 coupe with Bose although all Bose has been removed.
I appologise, I listed the incorrect metra model no. I used the 70-7550 as per Wrathernaut's recommendation in his post, not the 75-7550 which as you correctly pointed out, would not work with my car. Again sorry for the misinformation.
Thank you.
Thank you.
Compatibility List:
Infiniti:
1991 - 2002 G20
1996 - 2001 I30
1990 - 2002 Q45
1997 - 2002 QX4
Telcoman
Compatibility List:
Infiniti:
1991 - 2002 G20
1996 - 2001 I30
1990 - 2002 Q45
1997 - 2002 QX4
Telcoman
Thank you.
Thank you.
on
Thank you very much for the responses. Yah this one is making me want to pull my hair out but unfortunately there's not as much left to pull out as there was a few years ago.
There are about three pages of things to check if there are beeps at startup and no display, which is exactly what I have. I was hoping for an easier out, that would not involve me having to take everything apart... again and my favorite part, trying to hold the rediculously large and aukward audio, nav, climate control (which I don't have) units with one hand, while using the other hand to manipulate the gear shift out of the way, unplug or plug in the wiring harnesses, RCA's, mic, USB, connect the grounds, the antenna etc while making sure everything is nicely packed in behind the unit and nothing gets twisted, unplugged , pulled apart, cracked or otherwise destroyed, as the the unit is reinstalled. The last time I rested the whole unit on the shift lever and messed up what I guess is the digitizer on my hu.
Interesting you mention the pos. that the cllimate control is integrated and its absence could possibly be the problem. I wouldn't be surprised. Just when you think, after the years of being tormented by the system that shall not be named, it is finally out of your life, you find out that it still has its tenacles intertwined in your electronic. It's amazing that the car will start without The Blose system, in its entirety, assembled and fully functional.
I'm looking at the manual again. It appears that more than just the audio may be routed through the missing, no highs ...no lows... blose HU.
Anyone have a definitive resolution before I start taking stuff apart again?
Thanks.
Thanks.
Thanks.
Thanks.
xnick101
08-23-2013 01:19 AM
mellinox
08-08-2010 06:16 PM
Bkizz
02-17-2010 12:41 PM
lady1369
12-21-2009 02:14 PM
tjlazer
03-16-2008 03:02 AM
