05 Sedan Speaker Question
Old 02-09-2017, 06:39 PM
leeman's Avatar
Hi all,
One of my rear door speakers is well on its way out and I am just thinking of replacing it with another used Bose speaker on ebay. Are all 4 speakers in the doors, minus the tweeters the same? On ebay they show compatibility for one car and then show its from an other in a different location. I can pick up a used one for $23 after shipping.
I did hymm and hah over just buying just a new set on Crutchfield for $59 for the Polk DB651 but it seems like some modification is to take place to make them work, and I am not sure how they will sound mixed into the rest of the stock Bose system. Everything I have read tells me these speakers are 6.5 in size, yet on Crutchfield everything in that size comes with the minor mod warning yet they still recommend 5 1/4 as well speakers and show they fit as is. Any recommendation for those who have just swapped a set a speakers out and left everything else as is.
I have no plans to upgrade anything else as I have had this car since 2005 and will be ready for a change in a year or so. Thanks in advance.
Old 02-09-2017, 07:33 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Received 1,036 Likes on 609 Posts
Yeah, they're the same speaker front/rear.
Not sure why crutchfield recommends the 5 1/4, probably just for easier depth adjustments.
All you need to use a different speaker is a spacer - zenclosures sells well-cut MDF spacers, but if you have a router, you can make your own pretty easily.
Old 02-10-2017, 10:53 AM
leeman's Avatar
Good to know on the speaker spacer. If I go with teh aftermarket Polks, would these be a decant replacement? Just curious how they will sound mixed in with the rest of the sub par Bose system.
Old 02-10-2017, 11:38 AM
ACSanchez's Avatar
Always better to replace speakers in pairs, and always better to upgrade when you have the chance! I always found my factory system to be lacking, I'd find the best speakers you can afford and swap them. It's an easy install.
Old 02-10-2017, 10:29 PM
They'll be fine, biggest difference will probably be the sensitivity, so you'll have to fade it front/rear to equalize the volume.
Sound quality-wise, you're still limited by the bose amplifier until you replace it.
