Wiring Diagram for 05 DVD-Nav Conversion
Guest
Posts: n/a
I have successfully installed the TVandNav2Go converter for my 05 Coupe. I found the documents that they sent to be peices of the puzzle that I put together. So rather than have the next guy try to figure out where everything goes, I have created a Visio diagram of how to connect up the system.
I simply tapped into the cigarette lighter for Acc. Power and Ground. Works perfectly fine. If anyone has any questions about this, let me know.
UPDATED: New diagram with more details.
Awesome post. I really needed that.
I have installed just like your diagram but I keep getting a scrolling black line in the picture. I think it has something to do with the YS wire, the service manual says its for illumination and sync. I noticed that on your diagram you have something connected to that wire. What is connected there? My converter doesnt have anything to connect there. Is it a simple toggle switch? Thanks!
Mark
05 Black 6MT Intake & Borla
NC
Mark
NC
Hi cbrmark923
Do you have plug and play or not??? If not, your unit is NOT the same are the original unit, so the above wiring will NOT work. You have to tie 2 wires together which is what it should show in the diagram you got. Please call me at 718-763-7367 and I will explain it to you.
Thanks Dominic www.TVandNav2Go.com
Mark
NC
Mark
NC
Dominic,
No my unit is not the plug and play. It does have the serial looking cable, toggle switch and power. I appreciate you offering your number. I will probably give you a call tomorrow, unless someone has some ideas.
Thanks
Mark
BTW - You can VERY easily setup your website to sell products online. And it wouldn't cost you a thing. I can give you a hand if you like. Checkout the program osCommerce http://www.oscommerce.org Its a free shoppingcart store with every feature you could want, and I have a lot of expreience with it, if you are interested.
Thanks
Mark
Originally Posted by tvandnav2go
Hi cbrmark923
Hi cbrmark923
Hope all is well. Thanks for the offer but the reason why we don't let customers buy online is because sometimes they order the wrong item for the wrong car. You should have a diagram in the box for the wiring, if not I can fax it. It is a similar idea to what you posted, but the color of the wires will not be the same. Feel free to call me at 718-763-7367 and I will be more than glad to explain.
Thanks Dominic www.TVandNav2go.com
Dominic,
Thanks
Mark
Thanks
Mark
Ninjay16
Audio/Video/Electronics
11
02-26-2018 06:14 PM
master111
10-06-2015 01:36 AM
