Quote:
Originally Posted by purenv
I am new to the forum and i have read the entire thread on "installing aftermarket amps using the factory HU". I own a 06 g35 coupe w/bose and i'm a little confused on the inputs to the factory amp. Are they a diff. balanced line? If so, what LOC specifically do i need to use to convert the singal so a normal non-balanced input amp can be used? or is this even possible? the amps i am wanting to use are an alpine PDX 4100 and PDX 1000.
When searching for this do a search for balance receivers. Line Output Converters normally take balanced speaker level outputs and convert to rca level inputs. Most are inductor based and from I have been reading the effect is typically muddy sound at best. Look for IC based balance receivers.
