MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > General Discussion > Motorsports > Autocross/Road
User Name
Password
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Search this Thread Rate Thread Display Modes
Old 05-27-2008, 12:33 PM
Best Wheel and Tire Combination for Autocross
Hey Guys,
I am going to buy a new set of wheels and tires for autocrossing. Someone correct me if I am wrong, but I believe you are allowed to get wheels that's width is within 1" of your factory wheels, without changing class. With that, you could go 9" up front and 9.5" in the back. I am leaning towards going with 17's vs 18's. Unless anyone has a better argument for 18's.
For the tires, I am getting a bit confused with the measurable rim width vs the rim width range. When buying a tire do you want to make sure the rim width is equal to the measurable rim width for the tire or just with in the range? What are the pros/cons for being above/below the measurable rim width?
So what does everyone have or recommend for a wheel and tire size combination?
Old 05-27-2008, 12:41 PM
GreenGoblin's Avatar
SFLG35 President
I use 18's for auto X
__________________
SFLG35 Club
Dm2 * Mad Mods Paint
Old 05-27-2008, 12:46 PM
Quote:
What width and tires?
Old 05-27-2008, 12:51 PM
Glex25's Avatar
I use 18's for Autox
18x9.5
275/35 all around
Track Setup
I run in U class @ motorsportsne.com
Never seen u there.
Usually I'm the only G apart from one other guy that comes once in a blue with a black G35 he runs 17's.
Before i was running 18x8.5 and 18x9.5 in rear.
__________________
Quote:
Originally Posted by Billhyco
R. E. V. U. P.-Remember Each Victim U Pwnd
A nickel bag gets sold in the park I want in
Old 05-27-2008, 04:28 PM
And the 275's don't rub up front? What tire are you running?
What puts you in the U Class?
I was at the Motorsports NE PM Autocross on 5/23, and will be at the Sunday 6/8 one.
Old 05-27-2008, 04:35 PM
SFLG35 President
I use a 245 35/ 18 f and 275 35/ 18 r
__________________
SFLG35 Club
Old 05-27-2008, 05:07 PM
Glex25's Avatar
I was there on the 04/06.
If you look at the results on the website under U-Class you will see a G35(0781).
I haven't been able to make it for the Friday events cause of work.
as to what puts me in U-Class:
APS Twin Turbos
Coilover Suspension
Camber Adjustments on all 4 corners
Strut Bar
Chassis Braces
Adjustable Swaybars
275/35 slicks in rear and RCompund in the front(haven't put those on the track yet)
Rotora BBK
Cusco RS LSD(1.5 way 60% lock)
I think that covers most of the mechanicals that puts me in U-Class.
Don't have to worry about me getting better times than you most U-class get worst time than the lower classes since its more power to control.
Next up is some weight shaving
__________________
Old 05-27-2008, 05:14 PM
Were you in your G35 because I was there for the Friday 2PM autocross at Giants Stadium and I was the only G there.
Old 05-27-2008, 07:16 PM
Glex25's Avatar
sorry read my post again.
I haven't been able to get to any Friday events cause of work.
__________________
Old 06-04-2008, 04:15 PM
Hmm, are we talking about SCCA solo2 autox here?
__________________
“My car is so fast if I’m not careful I’ll go around the earth and rear end myself….That’d be a insurance nightmare.”
Old 06-05-2008, 10:17 AM
gunluvS14, yes.
Old 06-05-2008, 12:43 PM
Hmm, so what the heck is U class?
the only "U" I heard of is STU class, which allow up to 275 width tires, but it still has to remain with 140 treadwear minimum.
if he has twin turbo, that should bumps him into SM class right away
__________________
Old 06-05-2008, 12:53 PM
Glex25's Avatar
http://www.motorsportsne.com/2006/ru...s2006_0517.htm
__________________
Old 06-05-2008, 06:24 PM
well that's why I asked if it is SCCA solo2, that's not SCCA rule.
SCCA has stock class, touring, street prepare, street modified, prepared class, modified class, and sometime formula jr if there's any.
you are speaking of MotorSports NE which tied with HPDE
__________________
Old 06-10-2008, 03:14 PM
is the G a decent contender in autocross?
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Search this Thread:
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Powered by vBulletin Version 3.5.2
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
