ABS Failed - Help
ABS Failed - Help
Had a problem this weekend at the track. I was going into a corner and braking from 90 down to about 30 on a tight corner and the ABS failed to work properly. I locked up the right front and almost went off the track. I flat spotted the right front and ruined the tire. The ABS light and the slip lights came on. When I got back to the paddock and shut everything down there was a noise coming from the area of the brake fluid resevior area. It sounded like a fan or a pump runing. I thought it would stop once it cooled down but never did and I had to disconet the battery to get it to stop. Once I did that the lights on the dash went out and I didn't have any furture issue as I drove home.
Any ideas as to what cause this would be appreciated
THMotorsports
Suspension-Vendor
257
12-18-2018 05:43 PM
Thebaws11
11-30-2016 12:54 PM
