DIY: $10 Bumper Plugs
Old 01-12-2007, 04:15 PM
2001Z71's Avatar
This is a little DIY I did because I couldnt justify spending $30 on bumper plugs. Hope this is easy to follow and saves some people some money.
Heres how to make your own Bumper plugs for $10:
Supplies needed:
Hillman 7/16 Nylon Hole plugs (Black)
OEM Touch Up paint
Spray Enamel
220 grit Sandpaper
Pocket knife
Steps:
1. Go to your local Lowes or Home Depot and buy Hillman 7/16" Nylon Hole plugs in Black. Also buy some spray enamel or clear coat for added durablilty.
2. Buy OEM touch up paint if you dont have some already. Its about $8.00 and you will need it in the future anyway.
3. The plugs are not smooth on the top, so I sanded them with 220 grit sandpaper, which will also help the paint adhere. Wipe them off so no plastic dust is left.
4. Set the plugs so they will be easy to paint and will not get knocked over, I just pushed them in about 1/4" into a piece of styrofoam.
5. Shake up the touch up paint for a long time, then apply a thin single coat of paint to each plug. Let them dry for 20-25 minutes. Repeat this step as many times as necessary. (I used about 6 coats)
6. After they are totally dry, I hit them with 3 coats of spray enamel (about 10 minutes apart) for added durabilty. Then let them dry for a day or so.
7. The 7/16" plugs wont fit in the holes, you need to bore the existing holes out ever so slightly to ensure a tight fit. I used a pocket knife and did one round in the hole. After that the plugs will barely fit, you have to push them in. Be very careful not to make the hole too big!
8. Pop both of those babies in and bam! Youre done. Then take your girl out to dinner or something with the extra $20 you saved
Before Bumper Plugs:
After bumper plugs:
Old 01-12-2007, 04:21 PM
akachi's Avatar
nicee.. very useful tip
Old 01-13-2007, 12:29 PM
Calvin's Avatar
Overglorified Altima
thanks for the write up
Old 01-13-2007, 12:34 PM
Hi-TechG35's Avatar
Location: Pothole Central and still ridin slammed...Boston
Nice. Now if only it was easy enough to ride around without a front plate.
Old 03-22-2007, 08:54 PM
bikinilust's Avatar
Dude... In what department @ Home depot are these Hillman's Hole plugs ???
Old 03-22-2007, 08:55 PM
bikinilust's Avatar
I noticed your spray paint is from Walmart. Is that where you got the hole plugs?
Old 03-26-2007, 10:22 PM
bikinilust's Avatar
Ok. Here's the update for those of you who are planning on doing this mod. I could only find these "Hillman's Hole Plugs" @ Lowe's and they are in the hardware dept. Over there in that dept. you will see a bunch of drawers full of misc. hardware. Look for the drawer that says "Nylon plugs" or "Nylon Spacers" or "Nylon" something like that. And i recommend those of you to get wet sand paper. The 220 grit leaves a little rough finish, so either use both, or just the wet sand paper. It leaves a perfect finish. Good Luck
Old 08-24-2007, 05:51 AM
machspeed's Avatar
cool, good tip, thx
Old 08-24-2007, 01:24 PM
reverse's Avatar
nice...now can someone tell me how to cover up that big a hole that the license plate covers?
Old 08-24-2007, 04:25 PM
Calvin's Avatar
go buy a tow hook cover (~$10) and have it painted.
Old 12-25-2007, 01:46 AM
O HELLA JDM's Avatar
nice nice...ill tell my friend about this
Old 04-23-2008, 05:32 AM
officerdbag's Avatar
Bump for a great DIY.. Just finished this and it saved the look of my front bumper.
Old 05-28-2008, 03:50 PM
RunLevelZero's Avatar
Thanks bud this is exactly what I was needing. I let the dealer know that they should ask before putting on front plates especially in a state that doesn't require them.
Old 07-03-2008, 03:05 PM
Knoxrower's Avatar
I just did this mod using your instructions. The paint was a little tricky because my cars IP but it came out great. Thanks!
Old 01-16-2009, 01:47 AM
spankey167's Avatar
Came across these plugs at Home Depot
Seem to be better because they have locking clips.
Good luck!
Quick Reply: DIY: $10 Bumper Plugs
