DIY: 2006 Projector Cutoff/Color Mod
#316
first one was a snap to get right. I had to use 3 spacers from TRS, in person you can see (top-button) purple, dark red, Orangeish, blue, and teal Inside shot Second one needs more work. I took a picture of the second one from inside using 3 spacer as well but it was no where near the sharpness or the color of the first projection, so I cut my own spacer out bring it to 4 spacers total which cleaned it up nicely. But on the outside shot it was way,way off. It had no sharpness and way to much color compared to the first one.
#317
Tru. Distance wise both seem to have the same level of sharpness. But I need a better backdrop then just trees. And fresh bulbs, these that I'm useing are cheap-o's off eBay that are almost 2yrs old. Both are 8k bulbs but one is white and the other some weird color output.
How did your cut off turn out?
#318
Tru. Distance wise both seem to have the same level of sharpness. But I need a better backdrop then just trees. And fresh bulbs, these that I'm useing are cheap-o's off eBay that are almost 2yrs old. Both are 8k bulbs but one is white and the other some weird color output. How did your cut off turn out?
#320
#321
#322
**Honestly, this is the first time I've done something like this and I have no idea what the inside of 05 headlights look like**
I don't see why not.. I mean the houseing are the same size, right. Mounting and aiming them would hard since there may not be the three bolts like the 06s use.
n2fooz
09-04-2015 07:46 PM
