DIY Paint Headlights
I did this last friday and I can provide a few tips / insight.
The socket size you need is 10mm for the bolts to get the headlights off. One thing that took me like 2 hours to figure out was removing the actual headlight. The instructions say to unclip the wiring from the back and pull the whole headlight forward. The entire 1-2inch black section slides off the back of the light, then you can push in a screwdriver to detach it from the car.
Also you said you have to unscrew the yellow groud wire, All I did was turn that big silver thing to the right or left and it popped off. I took the bulb out and that was it. I didnt unscrew the balast or anything light that.
I turned the oven to 225 degrees and left them in for about 15-20minutes cause i was afraid heh, I was able to pry the lights open with a screw driver until i realized more heat made it much easier.
After I took the lights apart I painted my housings black then windexed the inside of my lights because i had fingerprints all over them. Got everything back in then smashed the lights back together using my hands so it would fit back in the oven. I let them back for another 10-15 min then pulled them out and actually used some vice grips to get everything in snug.
I did not use any extra silicon or anything like that and I was good to go.
Overall this mod took me about 4-5 hours but If I had to do it again I could get the lights completely off in like 20min. Take your time and be patient it really turns out great when you are finished.
#30
