DIY: side marker blinker mod
Old 11-03-2008, 01:06 PM
jaedoggz's Avatar
it hard to see the amber while the white strip is on
Old 11-03-2008, 01:14 PM
codeflux's Avatar
holy ancient thread revival, batman!
Old 11-09-2008, 03:31 AM
takashi kastl's Avatar
Since that video ive opened my headlights again, and replaced the stock blinker with a 2switch 7443 led bulb, and rearanged the position of the orange led so it is clearly visible. Im gonna make another video soon.
Old 11-10-2008, 08:50 PM
Beebo's Avatar
i did this a month ago about. if you like i'll do a quick write up if you guys want to do it too, let me know.
http://www.youtube.com/watch?v=-co4vZb9wxQ
2 bulbs? blue and arange?
Details please
Thanks,
Wes
Old 11-18-2008, 07:45 AM
jaedoggz's Avatar
i used one bulb. it is call switchback bulbs. it stays white with your running lights on and shuts off and blinkes amber during turning. you have to customized the back of your turn signal to fit a larger bulb.
Old 11-20-2008, 08:51 PM
Beebo's Avatar
Where did you buy the bulbs?
DIY?
Old 11-25-2008, 06:47 AM
jaedoggz's Avatar
DIY?
you can find them on autolumination.com but like i said to have to buld the back of the lens so a larger bulb could fit
Old 11-29-2008, 08:37 PM
Beebo's Avatar
Thanks
Old 02-04-2009, 10:11 PM
broke_as_ajoke's Avatar
I have notice one different videos that.. 1 video) the clear strip blinks when the turn signal blinks and then turns back white or clear when it's not blinking) 2 video) when the blinker blinks the clear strip turns amber.
To me these DIY's seem to be confusing.. Then one guy said he use a different bulb, however the "video 2" the guy didn't say he used a different bulb.. Someone tell me if i'm wrong
Old 08-04-2009, 01:22 PM
potmilkz's Avatar
i want to do this but it seems confusing as wel.. maybe someone can clear things up?
Old 08-04-2009, 04:34 PM
jaedoggz's Avatar
ok guys, my car is the one that changes color, white while running light is on and alt. amber when flashes. if the running lights arent on they flash amber. i think mine was the second video.
1. i bought these bulbs called switch back bulbs.
2. i bought a 3 way bulb socket. (3 wires)
3. i ran 1 wire to the (+) wire on my front
turn signal to the side marker.
4. build a different backing on the side maker to fit a larger bulb.
5. splice and sodered another wire into the (+) wire
6. splice and sodered another wire into the (-) wire
7. you are not going to use the old socket, i did this so if i wanted to go back to stock the socket could be accessed.
A. so now you have the 1 (+) from the front blinker
1 (+) coming from the running light
1 (-) coming from the running light
B. after you made the new light socket fit into the back of the lens
now
C. after everything fits good here comes the easy part the wiring.
D. connect the (+) wire from the front blinker to the new socket (green or white) wire. i forgot the colors
E. now connect the (-) wires from the running light the new socket wire.
F. connect the (+) wire from the running light to the new socket
G. you should have 3 wires all together going to that socket
and that is it. sounds like alot but it really isn't. all you are doing is running a (+) from the blinker to the side marker. and connecting the running lights pos. and neg. to a 3 way socket. just like any other factory 3 way bulb would be wired. the hardest part is fitting the new socket in the lens. that sould be it, good luck.
Old 06-27-2010, 01:51 AM
Beebo's Avatar
bump. what type of shop would know how to do this?
Old 07-06-2010, 12:36 PM
pythonjosh's Avatar
Beebo, anybody that knows wiring can do this.
I dunno what shop would do this, but if you had a shop do this for ya, they'd probly rape ya without lube.
I'd do it for $50 if you were in so cal.
Old 10-06-2010, 12:51 PM
paky786's Avatar
So basically in that DIY, you are running the black wire to splice into the purple-white for passenger side and then black wire on driver side to green-white wire and that's it right? The DIY was somewhat confusing on how to wire it all up
  #30
Old 10-15-2010, 02:18 PM
R10T_x's Avatar
Thats sick i wish i was brave enough to try this
Quick Reply: DIY: side marker blinker mod
